Pe tool error
Old   September 3, 2010, 05:03
Default Pe tool error
alf12 is on a distinguished road
I would like to use the Pe tool, I use pisoFoam solver with kOmegaSST turbulence model.
When I run the Pe tool from my case directory, I get the following error message :
    Reading phi
    Calculating Pe
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
--> FOAM FATAL ERROR:
    lookup of RASProperties from objectRegistry region0 successful
    but it is not a RASModel, it is a dictionary
What is going wrong ?
Thanks
alf12 is offline   Reply With Quote
Old   September 9, 2010, 10:18
I still haven't found what is wrong. When I am trying to use 'Pe' tool with cavity tutorial (incompressible/pisoFoam/ras/cavity), I get the same error. Should that work ?
Old   October 22, 2010, 15:57
Default more info
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
What version of openfoam are you using?
chegdan is offline   Reply With Quote
Old   October 28, 2010, 05:13
I was using version 1.6 and now I have switched to 1.7.1 but the issue is still present.
I have skirted the issue by commenting line 103 in the Pe.C utility (actually I have done another tool based on the Pe tool to deal only with RAS). I hope I have not messed up calculations.
IOdictionary RASProperties(RASPropertiesHeader);
Old   November 2, 2010, 17:56
Default I think you are ok
Daniel P. Combest
It seems that there has been a change in teh structure of the RASProperties file since the Pe tool has been made. The RASProperties file looks different from 1.5-dev to 1.6.x and 1.7.x and without the turbulence model coefficients being defined in the RASProperties file in later versions. It seems to be that your change doesn't affect the calculation since the conculation actually uses a laminartransport model to determine the nueff in the Pe calculation...rather than one calculated from a turbulence model.
this is seen in the lines
                singlePhaseTransportModel laminarTransport(U, phi);
                autoPtr<incompressible::RASModel> RASModel
                    incompressible::RASModel::New
                        U,
                        phi,
                        laminarTransport
                PePtr.set
                    new surfaceScalarField
                        IOobject
                            "Pe",
                            runTime.timeName(),
                            mesh,
                            IOobject::NO_READ
                        mag(phi)
                            mesh.magSf()
                          * mesh.surfaceInterpolation::deltaCoeffs()
                          * fvc::interpolate(RASModel->nuEff())
where the RASModel uses the laminarTransport transport property. This seems to be ok as long as there is a nu in the transport properties file to read into the Pe tool. hope that helps.
Dan
Old   August 20, 2011, 15:37
maysmech's Avatar
maysmech is on a distinguished road
Is it any solution found using Pe utility?
maysmech is offline   Reply With Quote
Old   August 25, 2011, 04:41
I'm still using version 1.7.1, so nothing has changed for me. Solution is to comment line 103 and to recompile Pe tool (likely as a separate tool)
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
[Netgen] Compiling Netgen on Fedora Core is driving me crazy jango OpenFOAM Meshing & Mesh Conversion 3 November 9, 2007 13:29
