December 14, 2010, 10:41 |
surface sampling during runtime
fisch
I' more or less beginner in programming in OpenFoam; so hopefully i'm not bugging you with silly questions... I want to do something like plane sampling during the runtime of my solver and at best i will have at the final end my sampling areas like the boundary patches to treat them in common in every timestep e.g. in paraview as vtk files. I tried to extract lines of the code of sample.C and of http://www.cfd-online.com/Forums/openfoam-programming-development/82878-averaging-due-parallel-running-cuttingplane.html but it was not working for solvers with meshmotion (produced memory access errors as soon meshmotion routines want to handle the mesh). I have no idea how to proceed... Can you help me? I'm thankful for every little advide. rupert |
December 14, 2010, 17:26 |
Bernhard
Rep Power: 21 |
I use the following for monitoring the free surface in an interFoam simulation. You have to put it in your controlDict. You can alter it for your case with the same definitions that are used in sampleDict. Have fun!
functions ( elevation { type surfaces; functionObjectLibs ( "libsampling.so" ); outputControl outputTime; surfaceFormat raw; fields ( alpha1 ); surfaces ( topFreeSurface { type isoSurface; isoField alpha1; isoValue 0.5; interpolate true; } ); } ) |
March 1, 2011, 10:39 |
Florian Ettner
Bernhard, thank your for this piece of code.
I would like to understand it a little better, but I cannot find the respective source code. It seems to me that functions() can be combined with a lot of stuff, but not the one I'm looking for... Which "types" are possible? So far I've found "surfaces", "probes", "fieldAverage". Which other options are there? Can I tell OF to continue the existing output file of a stopped run or does it always start a new file? Specifically, I would like to post-process some numbers (scalars) which I calculate during the run to characterize the flow. Thanks, Florian |
March 1, 2011, 17:03 |
Steven van Haren
us the famous "bananas" trick for problems like this:
type bananas;//fieldAverage; Code:
--> FOAM FATAL ERROR: Unknown function type bananas Valid functions are : 9 ( cellSource faceSource fieldAverage fieldMinMax probes readFields sets surfaceInterpolateFields surfaces ) |
March 2, 2011, 08:00 |
appending to existing output file
Florian Ettner
Thank you, Steven,
as far as I understand it now, a function object is created which takes the values from a runTimeSelectionTable which is provided by a library ("libsampling.so" in this case). However, the writing options seem to be limited to: timestep, outputTime The result is always written into a folder named after the starting time of the computation (e.g. probes/0.0/p). If the computation is stopped and then continued, it creates a new folder with the latest time step (e.g. probes/1.0/p) I would like to change this behaviour, so that it always writes to the same file and appends if it already exists (e.g. probes/p), but I cannot find the source code of this function object. Can anybody help me there? Thanks in advance! |
March 2, 2011, 09:42 |
Steven van Haren
Here is the source code for how the probes function samples and appends to a file:
/software/OpenFOAM/OpenFOAM-1.7.1/src/sampling/probes/probesTemplates.C |
March 2, 2011, 12:14 |
Florian Ettner
That's what I was looking for, thank you!
Somehow, I was looking for something like functions.C because I thought that's the class which determines I/O. |
November 1, 2012, 07:42 |
hello Bernhard,
I would like to ask you how do you know the sampling function input in controlDict? I just found the sampling file (.c and .H) but it didnt tell you how to use them. Is there any instruction about how to setup these ultities? Thanks Cloudy |
October 3, 2013, 07:52 |
Sampling for a specific timestep
Rob Gordon
Rep Power: 12 |
I was wondering if anyone knew how to output a cuttingPlane for a specific time step. I currently output horizontal slice surfaces at the outputTime but would like to output other surfaces at selected time steps. Is this possible? My cuttingPlane file Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ cuttingPlane { type surfaces; functionObjectLibs ("libsampling.so"); outputControl outputTime; setFormat raw; surfaceFormat vtk; interpolationScheme cellPointFace; fields (U UMean); surfaces ( vertPlane // I would like to output this at only select timesteps { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (-425 0 100); normalVector (0 1 0); } interpolate true; } horPlane2 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (-425 0 1.5); normalVector (0 0 1); } interpolate true; } horPlane10 { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (-425 0 10); normalVector (0 0 1); } interpolate true; } ); } |
April 30, 2014, 19:06 |
#10 | |
Dear Bernhard,
When we use the utilities you mentioned, can we get the velocity normal to and parallel with the iso-surface? Particualy when the iso-surface is curved. Do you have any experience with that? Thank you. OFFO. Quote:
February 12, 2015, 13:31 |
#11 |
Vignesh
Dear All,
I am simulating (2D) the shape of static meniscus attached to a wall. The interface is set horizontal at the start, which later changes its shape according to the contact angle defined at the wall, eventually forming a meniscus. I use the function object (given below) to extract the shape of the interface. I see oscillations of the interface when plotted, but i don't see it when visualised using paraview. Can someone explain why does it happen or how to rectify this ? Code:
functions ( elevation { interpolationScheme cell; type surfaces; functionObjectLibs ( "libsampling.so" ); outputControl outputTime; surfaceFormat raw; fields ( alpha1 ); surfaces ( interpolatedIso { // Iso surface for interpolated values only type isoSurface; // always triangulated isoField alpha1; isoValue 0.5; interpolate true; regularise true; } ); } );
Thanks and Regards Vignesh |
June 8, 2016, 05:28 |
#12 |
Agustín Villa
Hello
I know this thread is a bit old (even older threads were re-opened after a while), but if I have understood well, it is possible to use the commands I use in my sampleDict as function objects, as it is posted here. Am I right? |
February 7, 2022, 08:49 |
sample surfaces problem while running in parallel
#13 |
Rep Power: 4 |
Hello everyone
I am having the problem,while running in parallel, it only generates the planeA but not the left_x patch Does anyone know ? Thank you sampledSurface { type surfaces; libs ("libsampling.so"); libs ("libOpenFOAM.so"); writeControl timeStep; writeInterval 1; enabled true; surfaceFormat boundaryData; interpolationScheme none; interpolate false; triangulate false; fields ( U p ); surfaces ( left_x { type patch; patches ("left_x"); triangulate false; } planeA { type plane; triangulate false; planeType pointAndNormal; pointAndNormalDict { point (4.186 4.18 2); normal (1 0 0); triangulate false; //zone zone2; } } |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
sampling of a curved surface with distance-based coordinate? | johannesk | OpenFOAM Post-Processing | 0 | May 2, 2010 17:53 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
