-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   integrate several fields (http://www.cfd-online.com/Forums/openfoam-post-processing/86935-integrate-several-fields.html)
sixwp April 6, 2011 11:27
Hi foamers,
I'm doing a RTD (Residence Time Distribution) of a 3D cylinder. I solved the velocity part by using simpleFoam in a steady state.
Then, with this converged velocity I created a similar case (with scalarTransportFoam, transient), including a
step experiment at the beginning.
By measuring the Heat flux at the "outlet" patch, I would manage to study this RTD. (Hope you got everything:D)
My case briefly pre
sented, here's my question:
in the controlDict file, I want to use a function to calculate the integral for the product (Ux*T) during the whole calculation (t= 0 -> 3 with dt=2.5e-3)
I was trying to use "libsimpleFunctionObjects.so" with the type "patchIntegrate" as follows
flux
      functionObjectLibs ( "libsimpleFunctionObjects.so" );
      type    patchIntegrate;
      fields (T);
      patches ( "outlet" );
      factor Ux;
but:
There is no way to do what I exposed above.
Note: U isn't in the integral as it's constant for the whole calculation (already established).
Apparently you need a scalar and not Ux...
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar found on line 63 the word 'Ux'
1) Anyone has an idea how to do it?
2) Does it exist another utility to multiply 2 scalarfields? Then I'll be able to use the result of this one in my integral.
Thank you :)
sixwp April 7, 2011 03:15
My bad
I don't know what I was thinking about...:o
The integral is spatial and not temporal. Therefore, Ux isn't constant (as there is a laminar profile in the tube)!
I must multiply, then both Ux and T before integrating more or less as follows:
flux
      fields (Ux*T);
(Ux*T) doesn't work but that's the idea of what I wanna solve
gschaider April 7, 2011 07:27
flux
      fields (Ux*T);
@your recent posting: the factor always has to be a number that's why Ux didn't work. If you know the velocity you'd have to hardcode it here.
As what you're trying to compute isn't THAT uncommon SFO has a functionObject patchFieldFlow to do it (for compressible flow there is also a rho there, but that's alright I guess)
simpleFunctionObjects can't do arbitray calculations (Ux*T or so) on patches BUT swak4Foam can. The functionObjects there that can do that are patchExpression or swakExpression and they are based on SFO
Bernhard
sixwp April 7, 2011 08:53
Bernhard
Hi Bernhard,
First of all: thanks for your answer !
I was doing some tries with swak4foam before I saw your reply.
First of them, I tried to change (naively...) the "functionObjectsLibs" into that:
flux
      functionObjectLibs ( "libsimpleSwakFunctionObjects.so" );
      fields    (Ux*T);
but without success...
I was then looking at the wiki page (nice job for this contrib, btw) checking for examples. I couldn't find one that can help me.
Do you have any hints considering that?
Meanwhile, I'll continue to dig all of this.
Best Regards,
gschaider April 7, 2011 10:27
Originally Posted by sixwp (Post 302646)
Hi Bernhard,
flux
      fields    (Ux*T);
Best Regards,
Have a look at the Examples that come with swak. Especially other/angledDuctImplicit is bloated with functionObjects.
I hope to find the time to update the swak-Wiki-page when I find time (which should be hopefully before my retirement). Until then I welcome any contributions on it
Bernhard
sixwp April 7, 2011 10:34
Thank you so much. I was just about to leave a message saying I did use this example. I'm waiting for the calculation results.
I'll post what I did if effective (hopefully!)
gschaider April 7, 2011 10:39
Or (even better) you can add it as an example to the Wiki-page
sixwp April 7, 2011 11:13
If you don't mind, I'd rather post it here (or send you by email) first because if it works, it's a highly not straight forward way to do it I fear... :-p
Let's wait and see
sixwp April 8, 2011 08:43
I finally manage to realize my RTD! :)
The problem I had about integrating Ux and T together is solved. Here's what I used (it's definitely not the best way to do so, but that's a start):
First thing, in my case I admitted that Ux=magU (as the flow is almost perfectly unidirectional).
In controlDict, I input:
functions
      dflux
      type    expressionField;
      outputControl timeStep;
      outputInterval 1;
      fieldName    dflux;
      expression    "(T*mag(U))";
      autowrite true;
    flux
      fields    (dflux);
libs (
    "libOpenFOAM.so"
    "libgroovyBC.so"
    "libswakFunctionObjects.so"
    "libswakTopoSources.so"
Remarque: 1) The huge amount of libraries at the end isn't required (only some would be necessary). I just have them from a previous case and didn't optimize it.
2) I'm not sure if the dflux "patches" is correct or if the calculation is made everywhere...
As I said, it's highly inefficient compare to what's possible to do, but that's a start.
I wait for your comments before putting my example in the swak4foam wiki (if it's not too crappy:D)
Have a nice weekend :)
gschaider April 9, 2011 08:40
functions
      dflux
      outputInterval 1;
      fieldName    dflux;
      autowrite true;
    flux
      fields    (dflux);
libs (
    "libOpenFOAM.so"
    "libgroovyBC.so"
Hi.
You don't have to go through the expressionField. libsimpleSwakFunctionObjects.so already has what you need:
temperatureSum
        type patchExpression;
        accumulations (
            sum
        patches (
            outlet
        expression "mag(U)*T*area()";
        verbose true;
If you want the actual amount of T (which still is not the energy) flowing out this is better
temperatureSum
        accumulations (
            sum
        patches (
            outlet
        expression "phi*T";
        verbose true;
But if you had wanted that you would have used the patchFieldFlow from the simpleFunctionObjects
Bernhard
sixwp April 11, 2011 03:56
thanks for your answer.
I didn't want to use the patchExpression with "sum" because I thought it was only for an addition. I didn't push it further...:o
temperatureSum
accumulations (
sum
patches (
outlet
expression "phi*T";
verbose true;
Exactly ;)
[EDIT]: I tried to use your expression (to compare results) but I'm having some trouble with. It can't find the "linsimpleSwakFunctionObjects.so" apparently. Don't know what's wrong, I did "wclean" and "wmake" again, but it seems there's a problem with it. With OF1.7, I guess that's normal (as you put in your README) but with OF1.6dev, it should work...
Toorop December 1, 2011 10:27
To get to grips with the simpleFunctionObjects and swak4Foam I created a modified PD case to pisoFoam and injected scalarTransport into it - scalar T. I want to track the very uninteresting change of T in the domain and on the boundary. In the blockMeshDict I named all my blocks "domain".
I failed to create an expression for the difference of patchFieldFlow @ the inlet and outlet - main aim is to replicate the sumT expression with only boundary information only. Later I realized that I cannot reproduce the patchFieldFlow simpleFuncuntionObject with swak ...
At first I tried to somehow name (save) the two patchFieldFlow and make a subtraction. Is it possible to name / save it or to combine this with swak4Foam? My pure swak was crap as well ...
For the new sumT expression the timeStep information is necessary, how can one obtain the timeStep within swak?
There's some very similar stuff in the Examples / groovyBC / pulsedPitzDaily but I couldn't put it into practise.
functions
    massFlowAverageT
    type patchMassFlowAverage;
    fields ( T );
    patches
        inlet
        outlet
    factor 1.0;
    verbose true;
    patchFieldFlowT
    type patchFieldFlow;
    fields ( T );
    patches
        inlet
        outlet
    verbose true ;
    patchFieldFlowT_S4F
    expression "mag(Sf())*phi*T" ;
    patches
        inlet
        outlet
    accumulations ( sum );
    verbose true ;
    patchFieldFlowNettoT_S4F
        type swakExpression;
    valueType internalField;
    variables
        "inFlowT{inlet}=mag(Sf())*phi*T;"
        "outFlowT{outlet}=mag(Sf())*phi*T;"
        expression "outFlowT-inFlowT";
        verbose true;
    // total T in simulation domain
    sumT
    valueType cellSet;
    setName domain;
    expression "( T * vol() ) / sum( vol() )";
    verbose true ;
Thank you!
gschaider December 2, 2011 07:17
Originally Posted by Toorop (Post 334287)
functions
    massFlowAverageT
    fields ( T );
    patches
        inlet
        outlet
    factor 1.0;
    verbose true;
    patchFieldFlowT
    fields ( T );
    patches
        inlet
        outlet
    verbose true ;
    patchFieldFlowT_S4F
    patches
        inlet
        outlet
    verbose true ;
    variables
        verbose true;
    sumT
    valueType cellSet;
    setName domain;
    verbose true ;
Thank you!
Sorry for not answering to your post in more detail, but at a first glance I'd say that there is a slight misunderstanding on the definition of phi:
http://openfoamwiki.net/index.php/Ma...ver_is_writing
That means multiplying the surface is not necessary (actually it is wrong).
Also remote variables only work correctly if they are uniform. So for your difference you'll have to do the sums on the patches (inFlowT{inlet}=sum(phi*T)) and on the internalField accumulate the difference with min, max or average (they all should give the same result).
Whether checking for the "conservation of temperature" makes physical sense of course depends on your solver
Toorop December 5, 2011 12:09
4 Attachment(s)
Thank for the assistance!
With your advices I managed to pull it through, big thank you!
The only thing that still puzzles me is the slight difference in the the values - volume integration of the scalar and the calculated value based on the boundary flows. The latter gets accumulated in a variable, so there will be some error as the simulation progresses. But what causes the relatively big difference at the start, and the error wouldn't grow afterward, albeit it is not constant - quite strange! Attached the plots.
I attach the case since I usually find them quite useful if there's an attached project on the threads. So, the attachment contains a very simple extended pisoFoam solver with a scalar transport equation in it. The case is the pitzDaily with a scalar injected on the inlet. I used groovyBC to partition just the middle section of the inlet. I use simpleFunctionObjects and swakExpressions to track the evolution of the T scalar in the domain. I tried to replicate some functionalities with swak just to get some things sorted and learn a bit. At the end of the simulation pyFoam generates the plots.
gschaider December 5, 2011 20:14
Sorry. I currently don't have the time to have a look at the case.
Anyway: I don't think that the initial error is something to worry about. The relative error at the first time-step is (judging from your diagram) approx 10% and rapidly becoming smaller. Possible explanations are: the solution is not "totally correct" (try changing the tolerances of the linear solver and see if that error changes), error in the interpolation to the patches, time discretization: the summation at the patches is a pure explicit Euler while the other stuff depends on whatever scheme you chose for ddt
maalan January 7, 2014 07:27
Hi Bernhard!!
I am wondering how swak4foam and the libsimpleSwakFunctionObjects.so library compute exactly the integrals, I mean accuracy and method.
Thanks!
Best!
gschaider January 7, 2014 19:36
Originally Posted by maalan (Post 468965)
Hi Bernhard!!
Thanks!
Best!
What do you mean? Usually integrals are implemented in the user expressions: size of the discretization elements (=cell volume or face area) times the (cell or face value). Sum.
maalan January 30, 2014 07:46
Hi again and thanks for your reply!
Now I'm trying to integrate an expression on a patch via swak4foam. To do it I'd need the value of a field on another patch... I wonder if you could tell me how to do it with swakExpression.
Also, I'd need the time derivative of the velocity as I set an uniform velocity ramp at the inlet but I got the next message when I use the "ddt" function:
--> FOAM FATAL ERROR:
LHS and RHS of - have different dimensions
    dimensions : [0 1 -2 0 0 0 0] - [0 0 -1 0 0 0 0]
I have used both the OF BC's and groovyBC to implement the velocity ramp. Also, I have calculated the time derivative like that:
    dUdt
        fieldName ddtU;
//        expression "(U-oldTime(U))/deltaT()";
        expression "ddt(U)";
        verbose true;
        autowrite true;
But I don't get the expected results.
Thanks for your attention!!
Best!
gschaider January 30, 2014 13:04
    dUdt
        fieldName ddtU;
        verbose true;
        autowrite true;
Best!
A numer of questions:
- which OF-version
- which swak-version
- the fatal-error is without any context (so I could only guess what is going on). Try the following: "export FOAM_ABORT=1" and rerun. This should yield a stacktrace which would be helpful to see WHERE this is happening
- what is "expected results" and what are the results you get?
maalan January 31, 2014 06:49
At last I got it!! This is an example of the correct expression... I just wanted to call the value of the field on another patch...
        valueType patch;
        variables (
            "ddtUin{INLET}=(U-oldTime(U))/deltaT();"
            "ddtV{BODY}=(U-oldTime(U))/deltaT();"
        patchName CYLINDER;
        accumulations (
            sum
        expression "(ddtV-ddtUin)&normal()*area()";
        verbose true;
Now I have another problem... I know that to set a velocity ramp at the inlet one can do it by using both the uniformFixedValue function in OF and groovyBC. Well, I would like to set a ramp with the freestream BC and it's not possible to do it with 'uniformFixedValue', so is there any way to do it with groovyBC??
Thank you so much, Bernhard!!
Best!
