Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Python Scripting - basic help
Old   July 15, 2011, 13:14
Default Python Scripting - basic help
Ammar Tareen
atareen64 is on a distinguished road
Hello all,
I'm trying to analyze the boundary layer growth of a fluid near a wall in a simulation that I did with openfoam. The way I'm do that is that I take cross-sectional cuts of the velocity profile and plot the 2d data and look at the 99% value of velocity by eye and record the value.
This is a very inefficient way of doing it, and ideally I'd like to have a script that does that for me automatically. Writing python, C++ or Java programs isn't a problem for me, I just need to know how or where I can get started.
How would I get started doing something like this? Any help, pointers or suggestions are welcome.
Regards,
Ammar.
atareen64 is offline   Reply With Quote
Old   July 16, 2011, 03:12
Gijsbert Wierink
gwierink is on a distinguished road
Hi Ammar,
You mentioned you're familiar with python, so PyFoam is a nice place to start looking around.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   July 17, 2011, 21:37
Ammar Tareen
Hi Gijs,
I did look at pyFoam briefly and it seems like a great tool. However I was doing some reading and stumbled upon the sample utility: shouldn't I be able to do this boundary layer analysis just by using the sample utility?
Do you think that's true? I'll try it today and repost.
-Ammar.
Old   July 18, 2011, 02:38
matej forman
matejfor is on a distinguished road
I think what you can do is to use the sample utility or even the approach you mentioned at the start and add same C++ to do exactly what you want. you will find these in: $FOAM/applications/utilities/postProcessing/ dir.
matej
matejfor is offline   Reply With Quote
Old   July 18, 2011, 09:39
Assistant Moderator
Bernhard Gschaider
Originally Posted by atareen64 View Post
Hi Gijs,
-Ammar.
For getting the values you want the sample utilitiy is definitely the tool of choice. But for comparing the results of the different runs PyFoam may help you. Have a look at the pyFoamSamplePlot.py-utility. It allows you to quickly generate the gnuplot-commands to visualize the sample-data. Since the last version it also has the possibility to compare the current case to a reference case, write the data to a format Excel (or others) understand (CSV) and compare the solutions using some simple metrics.
I'm afraid "pyFoamSamplePlot.py --help" is all the documentation you're going to get, but it shouldn't be too hard to figure out how to get all this
Bernhard
Last edited by gschaider; July 18, 2011 at 10:19. Reason: Insert paragraphs that were swallowed by the MessageBoard
Fieldview 11.1 + Python to extract 3D core of data Rebecca FieldView 0 April 13, 2011 13:06
Basic Blade Design Code apoorv Main CFD Forum 0 April 5, 2010 06:37
python scripting in paraFoam chegdan OpenFOAM Post-Processing 0 March 31, 2010 19:06
[OpenFOAM] Paraview3 python scripting tomislav_maric ParaView 1 October 6, 2008 16:47
Programming C, Basic george Main CFD Forum 3 September 12, 2006 22:42
