A problem on the Energy spectrum plot by using FFT |
August 21, 2013, 05:55 |
Hi, guys
I am using the FFT to plot the energy spectrum of the turbulent velocity at the axial direction. but the figure shows that the sidelobes decrease very fast at the high frequencies, just as shown in black rectangular in the attached figure. I spend a lot of time to find out the reason. If you come across such problem before, please give me some clues. P.S. The precision of the original singular is double precision. Thanks in advance. |
October 23, 2013, 13:13 |
I have used the Spectrum Function for LES data from the following link and it worked out fine.
Python Scripts for Turbulent Statistics |
February 23, 2014, 04:23 |
Rep Power: 14 |
Hello guys!
I am simulating flow through a constricted pipe at Re=1000 using LES. DNS studies available in the literature predicts it as fully turbulent, and I am also getting similar results. I probed velocity at a suitable location and wrote a code in octave to create the spectrum. But I am getting the same trend similar to Martin's case. Towards the higher frequencies, the oscillations in energy are gone, and the curve looks like a straight line. Is this correct? Is there any problem with the simulation? or the fft code is the one to blame? Somebody please give some advice.. Thanks a lot for your time and consideration. |
April 20, 2014, 10:24 |
#4 | |
Huang Xianbei
Rep Power: 13 |
February 22, 2016, 10:11 |
#5 | |
Mr.liu
Rep Power: 13 |
February 22, 2016, 10:12 |
#6 | |
Mr.liu
Rep Power: 13 |
double precision, energy spectrum, fft, sidelobes |
energy problem | dldl | FLUENT | 2 | February 6, 2011 07:02 |
LES: Energy spectrum | Hummi | Fidelity CFD | 0 | June 16, 2008 16:21 |
Energy spectrum LES | Hummi | Phoenics | 0 | June 16, 2008 16:18 |
Energy Spectrum | Emad Khalifa | Main CFD Forum | 3 | June 30, 2003 16:03 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
