-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   foamDataToFluent (http://www.cfd-online.com/Forums/openfoam-post-processing/93160-foamdatatofluent.html)
greel October 6, 2011 14:38
foamDataToFluent
Hi Im trying to export the openfoam data to fluent, but when I use the foamDataToFluent command I get an error.
Im running the elbow test case from incompressible/icoFoam tutorials folder.
After I run the icoFoam solver I do this:
foamDataToFluent elbow.msh
Getting this error [QUOTE]
usuarioubuntu@SAN1496UBU:~/OpenFOAM/usuarioubuntu/run/tutorials/incompressible/icoFoam/elbow$ foamDataToFluent elbow.msh
Usage: foamDataToFluent [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-latestTime select the latest time
-noFunctionObjects
do not execute functionObjects
-noZero exclude the '0/' dir from the times list, has precedence
over the -zeroTime option
-time <ranges> comma-separated time ranges - eg, ':10,20,40-70,1000:'
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-2.0.0 (see www.OpenFOAM.com)
Build: 2.0.0-d79727c3fca7
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 1
FOAM exiting
[/QUOTE
Thanks!
