-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Output force distribution for each face on a patch (http://www.cfd-online.com/Forums/openfoam-post-processing/93573-output-force-distribution-each-face-patch.html)
meh October 19, 2011 11:21
Hello.
I'm really sorry if this question has already been asked, I couldn't locate the solution in the forums.
I can output the integrated pressure and viscous forces on a patch using libforces.so. I've also managed to output pressures and stresses per face using the sample function.
What I need is the forces per face on a patch, together with the coordinates and area of each face. I'll be using this to input to a fluid structure interaction model.
Can anyone advise how to output the distribution of forces on a patch, rather than just the integrated value?
Thanks very much for your time
Matt
boger October 20, 2011 09:25
I'm not sure I understand. If you're able to output the pressure and viscous stress per face, then don't you just need to multiply by the face area?
meh October 20, 2011 09:27
Hi David
Thanks very much for your reply. Using sample i've only managed to output a vtk file, which doesn't have face areas in it. Can I output face area using sample?
Thanks very much
Matt
boger October 20, 2011 09:37
Ah - now I understand, but I don't know the answer. I assumed you were modifying a utility like patchIntegrate or wallShearStress, in which case you should be able to modify the utility slightly to write out what you need. Someone else probably has a more elegant solution.
meh October 20, 2011 11:07
I'll have a look at these utilities, thanks. If there any other ideas out there I'd be glad to hear them.
