[swak4Foam] whats the trick to access to second layer of patch neighbors in groovyBC? |
July 8, 2013, 21:49 |
Ehsan
Rep Power: 26 |
i want to use an expression on outlet so that the pressure on the patch be to say 100000 less than internalField,
But for more smoothness its good to have access and participate second layers of neighbors in expression too. How can do it?is it possible or not(with or without groovyBC)?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
July 9, 2013, 06:43 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 9, 2013, 06:59 |
Ehsan
Rep Power: 26 |
thanks.
what does "corner-cases" mean?
July 9, 2013, 08:14 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request Last edited by gschaider; July 9, 2013 at 08:36. Reason: Link wrong |
July 9, 2013, 08:58 |
Ehsan
Rep Power: 26 |
what interesting site! google was filtered some days ago!
but I mean what corner cases may occur,in what sense?
July 9, 2013, 11:14 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Draw a regular grid with a corner (concave and convex) on a piece of paper and think what the second layer of cells is. In one case you have cells from the first layer in the second layer. In the other case there are cells missing that should have an influence. And that is an easy case
July 9, 2013, 13:01 |
Ehsan
Rep Power: 26 |
yes you right,that issue is for one or three cell but may be somewhat hard to write a program that realizes it but I have a thesis that have done it,I'll try to do this maybe some months later(after being light my works)and share!
now I think gradientExpession "-50000" for example works fine enough(acceptable).
Display Modes | |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 08:48 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 03:34 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
