Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Lambda2 or Q in multiRegionFoam
Old   December 7, 2011, 04:26
Default Lambda2 or Q in multiRegionFoam
Stefan
preibie is on a distinguished road
Hallo,
I want calculate Lambda2 or Q in the solver chtmultiRegionFoam. The program don't find the velocity Field U because the domain is spitted into solid and fluid regions.
How I can choose the right region?
Preibie
preibie is offline   Reply With Quote
Old   December 7, 2011, 04:49
Bernhard
Bernhard is on a distinguished road
You can easily upgrade the utility to read the correct U-field. Maybe it is enoug to change the name of the variable there?
Bernhard is offline   Reply With Quote
Old   December 7, 2011, 05:01
Stefan
Hallo,
copy the U field was my first idea but this is the result:
Time = 2000
    Reading U
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
size 613281 is not equal to the given value of 724217
file: /home/preibisch/OpenFOAM/preibisch-2.0.1/run/Waermerohr/Waermerohr_4/2000/U from line 18 to line 613347.
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/preibisch/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude/Field.C at line 236.
You mean is is easy to upgrade the utility. How do you do this?
Preibie
Old   December 7, 2011, 05:09
Bernhard
Originally Posted by preibie View Post
Hallo,
Time = 2000
    Reading U
--> FOAM Warning :
This means your reading a U file that does not belong to default mesh.
As usual: Copy the utility to a save place, and rename Lamba2.C to something else, then change the Make/files. By looking into the source code the chtRegion solver, you will find out how you can read the correct U or the correct mesh (look for createFields.H or something similar). Finally you can compile this by typing wmake. Good luck!
Old   December 7, 2011, 05:54
Stefan
That the U field dos not match with the mesh is clear because in the solid regions is no U field defined.
I copy the air/constant/polyMesh from the fluid field in the constant/polyMesh and now it works. I will write me a shell script.
Preibie
multiregionfoam + blockmesh + region property alvora OpenFOAM 0 March 23, 2011 06:03
regionCouple in multiRegionFoam mvoss OpenFOAM Programming & Development 1 March 7, 2011 13:02
MultiRegionFoam alvora OpenFOAM 0 March 2, 2011 07:40
