Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating mass flow and Yplus values
Old   October 25, 2011, 01:40
Default Calculating mass flow and Yplus values
petrile_83 is on a distinguished road
How do I calculate mass flow in outlet? Is is possible to do this in paraFoam?
I found posts how to calculate Yplus in older open foam versions. What is the easiest way to calculate Yplus in open foam 2.0.0? Can I use yPlusRAS? I have heard that yPlusRAS actually calculates Y* value. Is this the case with open foam 2.0.0 and yPlusRAS?
petrile_83 is offline   Reply With Quote
Old   December 17, 2011, 10:37
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Not sure if you still need this, but:
- For mass flow at the outlet, i use simpleFunctionObjects (http://openfoamwiki.net/index.php/Co...unctionObjects)
chegdan is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Calculating YPLUS and Compiling Multiple C files sanjibdsharma OpenFOAM Programming & Development 1 August 11, 2009 06:56
YPlus values underGroundMan CFX 2 July 24, 2008 10:51
YPlus values underGroundMan Main CFD Forum 2 July 23, 2008 17:14
YPlus Values and SST Model Jenny CFX 1 June 22, 2008 18:47
