Home > Forums > OpenFOAM Post-Processing
Plot Data from Probes
Like Tree3Likes
Old   March 20, 2014, 16:59
Timofey Mukha
tiam is on a distinguished road
Hi!
Have no idea why I didn't get that debugging idea, I guess the script fails on me totally or it works for everything. So it works on all fields but UPrime2Mean!
It looks like this:
# x 1.5 1.5 1.5 1.5 1.5 1.5
# y 0 0.1 0.2 0.3 0.4 0.5
# z 1.5 1.5 1.5 1.5 1.5 1.5
# Time
0.2 (0 0 0 0 0 0) (0 0 0 0 0 0) (0 0 0 0 0 0)
0.4 (2.7993e-08 -7.77667e-10 1.05859e-08 2.16042e-11 -2.94084e-10 4.00318e-09)
0.6 (3.17292e-08 -1.45928e-09 1.17226e-08 8.21429e-11 -5.31962e-10 4.33446e-09)
0.8 (2.85533e-08 -1.82099e-09 1.0425e-08 1.72582e-10 -6.48406e-10 3.81149e-09)
1 (2.40662e-08 -1.85896e-09 8.91598e-09 2.70264e-10 -7.08062e-10 3.32037e-09)
1.2 (2.01257e-08 -1.64986e-09 7.54823e-09 3.69006e-10 -7.58858e-10 2.96515e-09)
tiam is offline   Reply With Quote
Old   March 20, 2014, 18:33
Assistant Moderator
Bernhard Gschaider
Originally Posted by tiam View Post
Hi!
It looks like this:
# Time
OK. That explains it. That is a tensor field and that class only supports scalars and vectors
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 22, 2014, 06:12
Assistant Moderator
Bernhard Gschaider
The attached patch tries to make PyFoam more tolerant about this (it ignores, warns, but doesn't fail)
PyFoam_tolerantProbes.patch
Old   February 4, 2016, 08:18
ArielJ
arieljeds is on a distinguished road
Hi, I couldn't find a more relevant thread so I am reviving this one.
I am trying to use pyFoamTimelinePlot.py to plot values from probes but I can find NOTHING except for this thread to help me understand how to use it.
First of all, here is my probeDict file:
       fields
            p_rgh
            p
	    U
	    Ux
	    Uy
	    Uz
	    magU
	    vorticity
	    Co
// Locations to be probed. runTime modifiable!
        probeLocations
            ( -4     0     0 )	// 1 - inlet, in relaxation zone
            ( -2     0     0 )	// 2 - upstream
            ( -0.52  0     0 )	// 3 - upstream
            (  0.52  0     0 )	// 4 - at the larger radius
            (  2     0     0 )	// 5 -
            ( -4     0     0 )	// 6
            (  0     0.52  0 )	// 7
            (  0    -0.52  0 )	// 8
            (  0     3.9   0 )	// 9
            (  0     3.9   0 )	// 10
            (  0.37  0.37  0 )	// 11
            ( -0.37  0.37  0 )	// 12
            ( -0.37 -0.37  0 )  // 13
            (  0.37 -0.37  0 )  // 14
I am then trying the following things:
1) This command DOES work:
pyFoamTimelinePlot.py --fields=p_rgh --basic-mode=lines postProcessing/ | gnuplot
This produces a plot of, for example, the p_rgh field. However, this is not that useful because it is plotting ALL of the probes.
2) This command DID work but is now giving the error listed below:
pyFoamTimelinePlot.py --fields=p_rgh --basic-mode=lines --csv-file=p_rgh.csv postProcessing/
This has worked for me previously but is now giving:
Traceback (most recent call last):
  File "/usr/local/bin/pyFoamTimelinePlot.py", line 5, in <module>
    pkg_resources.run_script('PyFoam==0.6.5', 'pyFoamTimelinePlot.py')
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 499, in run_script
    self.require(requires)[0].run_script(script_name, ns)
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1235, in run_script
    execfile(script_filename, namespace, namespace)
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/EGG-INFO/scripts/pyFoamTimelinePlot.py", line 5, in <module>
    TimelinePlot()
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/TimelinePlot.py", line 34, in __init__
    **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/PyFoamApplication.py", line 424, in __init__
    result=self.run()
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Applications/TimelinePlot.py", line 463, in run
    spread=plots[0][-1]()
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/RunDictionary/TimelineDirectory.py", line 353, in __call__
    title="%s_t=%s" % (self.val,self.time))
  File "/usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Basics/SpreadsheetData.py", line 138, in __init__
    dtype=list(zip(names,['f8']*len(names))))
ValueError: two fields with the same name
This error and producing no output.
Therefore, I have two specific questions for plotting values at probes:
1) Is it possible to use pyFoamTimelinePlot to specify which probe to plot at? And how would I do this?
2) Has anyone had experience with the error above? I don't understand it at all because this was working for a different case and I can't see where I've gone differently.
Any help or advice is much appreciated... I've been spending a loooooong time on this now and getting frustrated with the lack of documentation (aside from the code itself)
arieljeds is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to plot the data made by java? jelon STAR-CCM+ 2 April 11, 2010 06:00
How to save 2-D data in contour plot mssound FLUENT 0 February 15, 2010 15:01
How to create an contour plot for arbitrary plane with interpolated data navaladi OpenFOAM Paraview & paraFoam 0 June 4, 2008 07:57
xy data from graph plot to excel Radhika CD-adapco 5 February 23, 2007 08:23
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
