How can I calculate fieldAverage in post-processing? |
January 11, 2012, 14:30 |
Rep Power: 15 |
Dear all,
I have got results of a chtMultiRegionFoam (2.0.x) simulation and I'd like to calculate a fieldAverage of T in a given region. Does anybody know how to do that? I know, that it is easy with function objects... but how do I call those during post processing? Thanks a lot for your help! Best, Moritz |
January 12, 2012, 04:07 |
Tibor Nyers
Rep Power: 16 |
in my experience, nothing is easy in OF! I had a similar problem a couple of months ago with a simple case (no multi region and stuff). Always start from the simplest problem and advance forward from that point - I nice advice that I always forget ... I checked the work around in my multi region case and the solution is: - make a separate file for post processing in the systems folder - this file should contain the FoamFile header and the functions. - didn't figure it out how to handle multiple domains simultaneously, so stick with one - the simpleFunctionObject worked for me, other postproc sampling didn't @systems/postproc Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // functions { T_air { type volumeAverage; functionObjectLibs ( "libsimpleFunctionObjects.so" ); region "air"; fields ( T ); factor 1.0; verbose true; } } // ************************************************************************* // Code:
execFlowFunctionObjects -dict postProc -noFlow -latestTime -region air |
January 12, 2012, 05:20 |
Rep Power: 15 |
Dear Toorop,
thanks for the reply. I was not aware of execFlowFunctionObjects. In my version of OF it does not accept the options -region and -noFlow which is why it won't work for my current problem. But in the future I will use OF 2.1 and there the options are available! Thanks again for the hint! All the best, Moritz |
January 12, 2012, 05:40 |
Tibor Nyers
Rep Power: 16 |
Hi Moritz,
I have 2.0.x as well so this shouldn't be an issue. Maybe an update to your current 2.0.x would solve the problem so make a git pull and a quick rebuild. Code:
cd $WM_PROJECT_DIR git pull wcleanLnIncludeAll ./Allwmake |
Tecplot for CFX post processing | pantangi goud | CFX | 2 | August 24, 2005 16:42 |
post processing CL values | Joe Bryant | FLUENT | 2 | October 18, 2004 04:17 |
looking for a post processing s/w | han | Main CFD Forum | 0 | May 9, 2001 22:44 |
PRE and POST processing package | Astrid Barros | Main CFD Forum | 6 | November 16, 2000 10:31 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
