-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   How to calculate CoG in interDyMFoam (http://www.cfd-online.com/Forums/openfoam-post-processing/96118-how-calculate-cog-interdymfoam.html)
anmartin January 12, 2012 17:40
I would like to calculate the centre of gravity of liquid fraction in a sloshing simulation.
Are there any options to calculate it in OF or in Paraview?
Regards
Angel
sail January 12, 2012 19:58
Regards
Angel
Hi angel.
i have never done it by myself, but i would use the threshold filter to selct just the cells with alpha_water > 0.5, and than use the calculator filter, in conjunction with each cell's coordinates and volumes, to obtain a new array with just one value.
good luck
gschaider January 12, 2012 21:16
Regards
Angel
You mean by calculating the weighted average of position of all the cells? Like this:
sum(pos()*alpha1*vol())/(vol()*alpha1)
In swak4Foam there is a functionobject swakExpression where the line
expression "sum(pos()*alpha1*vol())/(vol()*alpha1)";
will print exactly that at every timestep (OK. you've got to add a bit more to the controlDict, but it is less than 20 lines)
anmartin January 23, 2012 10:53
First at all, many thanks to Bernhard and Vieri for your quick response.
I’ve tried first, with swak4foam and after installed and read yours presentations, I finally discovered one easy way to obtain the cog that works for me, but not very smart, because in can’t remove the floating point exception.
This is my controlDict, with the different options that I have tried, and the results obtained, included the error:
libs (
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
functions
liquid_COG //simpleFunctionObjects:)
type swakExpression;
valueType internalField;
setName liquidCog;
accumulations (sum);
expression "(pos()*alpha1*vol())/0.034167"; //works
/*# Time sum
0.01 (0.000309988 0.0903394 0.25)*/
verbose true;
outputControl outputTime;
liquid_COG1 :)
setName liquidCog;
expression "pos()"; //works
/*# Time sum
0.01 (-401.694 14571.8 22412.5)*/
verbose true;
liquid_COG2 :)
setName liquidCog;
expression "alpha1*vol()"; //works
/*# Time sum
0.01 0.034167*/
verbose true;
liquid_COG3 :)
setName liquidCog;
expression "pos()*alpha1*vol()"; //works
/*# Time sum
0.01 (1.05913e-05 0.00308663 0.00854175)*/
verbose true;
liquidCOG4:confused:
//functionObjectLibs ("libswakFunctionObjects.so"); Not needed if it is called in libs ("libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so");
setName liquid_Cog;
//expression "(pos()*alpha1*vol())/(alpha1*vol())"; //Floating point exceptio
variables (
"posX=(pos().x>0.0001) ? pos().x : 0;"
"posT=vector(posX,pos().y,pos().z);"
expression "posT*alpha1*vol()/(alpha1*vol())"; //ERROR
/*Expression liquidCOG4 : #0 Foam::error::printStack(Foam::Ostream&) in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::Vector<d ouble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so"
#4 parserField::FieldValueExpressionParser::parse() in "/home/anmartin3/OpenFOAM/anmartin3-2.0.x/platforms/linux64Gcc45DPOpt/lib/libswak4FoamParsers.so"
#5 Foam::FieldValueExpressionDriver::parse(std::strin g const&) in "/home/anmartin3/OpenFOAM/anmartin3-2.0.x/platforms/linux64Gcc45DPOpt/lib/libswak4FoamParsers.so"
#6 Foam::swakExpressionFunctionObject::write() in "/home/anmartin3/OpenFOAM/anmartin3-2.0.x/platforms/linux64Gcc45DPOpt/lib/libsimpleSwakFunctionObjects.so"
#7 Foam::simpleFunctionObject::execute(bool) in "/home/anmartin3/OpenFOAM/anmartin3-2.0.x/platforms/linux64Gcc45DPOpt/lib/libsimpleFunctionObjects.so"
#8 Foam::functionObjectList::execute(bool) in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#9 Foam::Time::run() const in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#10 main in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/bin/interDyMFoam"
#11 __libc_start_main in "/lib64/libc.so.6"
#12 Foam::UOPstream::write(char) in "/home/anmartin/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/bin/interDyMFoam"
Floating point exception*/
verbose true;
By the other hand, in paraview, it is possible to obtain de volume with meshQuality, and then pass celldata to point data and obtain the cellcenters. Then is possible using the calculator to multiply coord(x y z)*alpha*vol, but I don’t know how to make the summation of all cell values.:confused:
If anybody knows how it is possible to solve these questiongs, I will be very gratefully.
Best regards,
gschaider January 23, 2012 18:24
Iíve tried first, with swak4foam and after installed and read yours presentations, I finally discovered one easy way to obtain the cog that works for me, but not very smart, because in canít remove the floating point exception.
libs (
functions
setName liquidCog;
/*# Time sum
verbose true;
liquid_COG1 :)
setName liquidCog;
/*# Time sum
verbose true;
liquid_COG2 :)
setName liquidCog;
/*# Time sum
0.01 0.034167*/
verbose true;
liquid_COG3 :)
setName liquidCog;
/*# Time sum
verbose true;
setName liquid_Cog;
variables (
verbose true;
By the other hand, in paraview, it is possible to obtain de volume with meshQuality, and then pass celldata to point data and obtain the cellcenters. Then is possible using the calculator to multiply coord(x y z)*alpha*vol, but I donít know how to make the summation of all cell values.:confused:
Best regards,
I think you'll want to write sum(alpha1*vol()) instead of alpha1*vol(). Because if in ANY cell the alpha1 is 0 then you get a division by zero there. Apart from that sum(pos()*alpha1*vol())/sum(alpha1*vol) is NOT the same as sum(pos()*alpha1*vol()/(alpha1*vol)) (which is what you wrote)
duongquaphim January 24, 2012 09:43
You can use function Filter -> Integrate Variables to make the summation.
Cheers,
Duong
anmartin January 27, 2012 07:21
Originally Posted by duongquaphim (Post 340861)
Cheers,
Duong
many thanks to everybody that helped me.
Work done perfectly.
Thanks again,
Ivooo March 5, 2012 10:20
A little utility
1 Attachment(s)
I created a utility to do just this, basically as a first step to get to know the coding style, but it works for me; it reads the alpha fraction for each time step and provides the centre of mass as a weighted average (with the cell volume), and the total volume and outputs these numbers to stdout.
I'll leave this just here in case somebody could use it. It's as simple as the ptot utility on which it is based, and it seems to work too on dynamic meshes. No guarantees ;)
(unpack in $WM_PROJECT_USER_DIR/applications/utilities/postProcessing/miscellaneous , go to alpha1Tot directory and run wmake - tested on v2.1.0)
