Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculate custom pressure - best way?
Old   November 22, 2011, 05:07
Default Calculate custom pressure - best way?
grjmell is on a distinguished road
I want to add rho*g*h to my pressure field as output by pimpleFoam. The options in my mind are:
1. inclusion of write.H to output p+rho*g*h (requires compiling new pimpleFoam solver)
2. post-process results with a utility to calculate p+rho*g*h
Have i missed an option? it seems option 2 is more appropriate since it only involves making a utility and no recompilation of the entire solver.
What is the best way to get the value for h?
Thanks
grjmell is offline   Reply With Quote
Old   November 22, 2011, 05:16
Nima Samkhaniani
nimasam is on a distinguished road
im not sure but as i know in new OpenFoam version we have two pressures
1) p
2) p - rho*g*h
so i guess the first p contains the effect of gravity! i insist im not sure
nimasam is offline   Reply With Quote
Old   November 22, 2011, 05:18
Bernhard
Bernhard is on a distinguished road
Either of the two methods will do. If you need it for every timestep or want to sample during runtime I would chose option 1. If you need it only every once in a while, then option 2 will do.
If you go for option 2, have a look at the existing ptot utility. It has almost everything you need.
For the calculation of h, you can have a look in for example the interFoam e.g. createFields.H line 109 reads
volScalarField gh("gh", g & mesh.C());
Which is probably what you are looking for. mesh.C() refers to the central coordinate of a cell.
Good luck!
Bernhard is offline   Reply With Quote
Old   December 15, 2011, 04:38
Thanks All. Ok, I've tried with
but that gives me the height of the cell from z=0, rather than the depth from top of my domain which is what i need in order to calculate the hydrostatic component g*depth rather than gh. How can I get the depth, i.e. domain height - h?
Old   February 1, 2012, 10:05
Fabien Farella
FabienF is on a distinguished road
Hi Greg,
I have the same problem. I would like to calculate the vertical offset from my boundary surface (the ground) of my mesh cell centers. Have you found a way to get the cell height relative to a surface/boundary?
Thank you
FabienF is offline   Reply With Quote
Old   February 1, 2012, 11:07
Hi Fabien,
No I haven't done much more on this. There must be a relatively easy way to find the max z value of the mesh to use as the relative datum. But not sure how... if you find anything please post!
G
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
custom pressure field at the faces Souviktor FLUENT 0 April 3, 2009 08:09
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
