Mapping results from plane or cyclic BC
Old   February 5, 2012, 21:41
Default Mapping results from plane or cyclic BC
ic3wall is on a distinguished road
I did a simulation of an atmospheric boundary layer. My inlet and outlet are cyclic, so considered as a single patch. Now I would like to take the results of the inlet (or outlet) and map them to another case having exactly the same mesh. The problem is that my cyclic BC called "inout" contains both the values at the inlet and outlet planes.
Is there a smart way of taking the results of only the inlet or only the outlet and map them onto the inlet of another simulation ?
I looked for a function to "un-couple" a cyclic patch, without success... I also looked for sampling a plane and mapping the results, but that also looks complicated ..
Does anybody have an idea ?
ic3wall is offline   Reply With Quote
Old   February 8, 2012, 09:16
nobody has an idea ?
Problem with Sampling plane Chander CFX 10 February 20, 2012 16:57
Interpolation Error on FAM Mesh with Cyclic BCs ngj OpenFOAM Bugs 1 August 9, 2011 06:12
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
[snappyHexMesh] snappyHexMesh with cyclic patches? Axel_T OpenFOAM Meshing & Mesh Conversion 1 October 12, 2010 10:03
Arbitrary Cyclic beta code luca OpenFOAM Running, Solving & CFD 0 June 13, 2007 10:10
