Home > Forums > OpenFOAM Post-Processing
Force on a patch
Old   March 14, 2012, 01:33
Default Force on a patch
Daniele Vicario
danvica is on a distinguished road
I need to calculate the force caused by the flow on a patch.
In the first picture you can see the result of the simpleFoam solver. In the second there's the patch I want to calculate Fx on.
I tried in Parafoam to integrate pressure on the surface but maybe I miss something (BTW, is there a tutorial regarding this managements ?)
Another simple question: p for incompressible solver is actually divided by density.
That means that the real pressure at the end has to be multiplied by density, right ?
Daniele
danvica is offline   Reply With Quote
Old   March 14, 2012, 04:04
Daniele Vicario
Probably I should have posted this under the parafoam forum. Is there any way to move it by me ?
Anyway, I tried the following in Parafoam:
1. Select the above patch.
2. Generate surface normals.
3. Use calculator to define a new var called Px defined as
p*N_x*1000. (where 1000 is density of water).
4. Integrate Px on the surface.
Is it correct ? The obtained value is in Newton, right ?
Old   March 15, 2012, 02:42
Daniele Vicario
Another way, more flexible is to use the libforces library as follow:
functions
forcespisto
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (pisto); // change to your patch name
pName p;
Uname U;
rhoName rhoInf;
rhoInf 1000;
CofR (0 0 0); //Origin for moment calculations
outputControl timeStep;
outputInterval 5;
I'm interested in the Fx value and it seems quite the same, compared with the one obtained by parafoam (see prev post).
Just a confirmation: is it right ?
Daniele
Old   March 15, 2012, 05:54
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hi Daniele,
Yes it is. Just modify the CoR (center of reference) if you want the values of Mx My and Mz.
There is also a "forceCoeffs" function for Cx Cy and Cz calculations.
Aurélien
Aurelien Thinat is offline   Reply With Quote
Thread Tools
Trackbacks are On
Using starToFoam clo OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 33 September 26, 2012 04:04
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
