Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamToVTK: load all the parts at once
Old   March 18, 2012, 08:59
Default foamToVTK: load all the parts at once
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi all;
if you run foamToVTK it creates a different folder for every .stl you got. That means that if you then want to load all of the parts composing your geometry, you need to load every each one of them separately since they are in different folders…
Is there any way to load all of them at once?
Thank you!
lovecraft22 is offline   Reply With Quote
[OpenFOAM] How to load all <case>/surfaces/*/*.vtk at once into Paraview holodeck10 ParaView 8 November 22, 2019 17:52
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 15:18
icem hexa - load different blockings for each part of geometry??? Catthan ANSYS Meshing & Geometry 2 May 28, 2010 11:27
[snappyHexMesh] SnappyHexMesh complex geometries amp thin wall parts hsieh OpenFOAM Meshing & Mesh Conversion 0 September 22, 2008 17:34
Using load vector for parallel partitioning Kevala FLUENT 0 May 1, 2001 12:11
