November 18, 2011, 08:00 |
OpenFoam help
Anirudh
Rep Power: 14 |
Dear all ,
I am totally new with OpenFoam CFD tool box..But unfortunately I was assigned a small project . I tried to understand and do on my own. And am Struck here. A simple geometry with three different velocities are given. And he specified simpleFoam steady state newtonian fluid. Actually my problem is here after running simpleFoam. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras --> FOAM FATAL IO ERROR: Unknown patchField type nutSpalartAllmarasWallFunction for patch type wall Valid patchField types are : 64 ( advective atmBoundaryLayerInletEpsilon buoyantPressure calculated codedFixedValue cyclic cyclicSlip directMapped directMappedField directMappedFixedInternalValue directMappedFixedPushedInternalValue directionMixed empty epsilonWallFunction fan fanPressure fixedFluxPressure fixedGradient fixedInternalValue fixedPressureCompressibleDensity fixedValue freestream freestreamPressure inletOutlet inletOutletTotalTemperature kappatJayatillekeWallFunction kqRWallFunction mixed nonuniformTransformCyclic nutLowReWallFunction nutTabulatedWallFunction nutURoughWallFunction nutUSpaldingWallFunction nutUWallFunction nutkRoughWallFunction nutkWallFunction omegaWallFunction oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip processor processorCyclic rotatingTotalPressure selfContainedDirectMapped sliced slip symmetryPlane syringePressure timeVaryingMappedFixedValue timeVaryingTotalPressure timeVaryingUniformFixedValue totalPressure totalTemperature turbulentHeatFluxTemperature turbulentInlet turbulentIntensityKineticEnergyInlet turbulentMixingLengthDissipationRateInlet turbulentMixingLengthFrequencyInlet uniformDensityHydrostaticPressure uniformFixedValue waveTransmissive wedge zeroGradient ) file: /home/anirudh/Desktop/Ani/0/nut::boundaryField::top from line 43 to line 44. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 135. FOAM exiting I couldn't get this error !! Could somebody help me in running this ! Thanks a ton in advance |
November 18, 2011, 08:07 |
Anirudh
Rep Power: 14 |
Later I found that in RASmodel : spallartAllamars
Turbulence : on I am looking for laminar one SO changed like this RASmodel : laminar Turbulence : on Is this entry a correct one ? By running this ..I get following errors anirudh@anirudh:~/Desktop/Ani$ simpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : simpleFoam Date : Nov 18 2011 Time : 14:01:11 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model laminar SIMPLE: no convergence criteria found. Calculations will run for 4 steps. Starting time loop Time = 0.005 --> FOAM FATAL IO ERROR: keyword div((nuEff*dev(T(grad(U))))) is undefined in dictionary "/home/anirudh/Desktop/Ani/system/fvSchemes::divSchemes" file: /home/anirudh/Desktop/Ani/system/fvSchemes::divSchemes from line 31 to line 41. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting |
November 18, 2011, 08:16 |
Olivier
Rep Power: 17 |
hello,
In 0/nut, you define a non valid boundary condition "nutSpalartAllmarasWallFunction" which is not valid in 2.0 You may change to "nutUSpaldingWallFunction", but you didn't give much info about your case. Take a look at the tutorial case : tutorials/incompressible/simpleFoam/airFoil2D/ regards, olivier |
November 18, 2011, 09:15 |
Anirudh
Rep Power: 14 |
Dear Mr.Oliver,
Thank you for the reply....In my case, I should consider an Block Mesh like this with following boundary conditions. And I have to use simpleFoam(steady state one) in order to visualize the laminar flow. And the related graphs.The flow medium is considered as a newtonian one,for three different velocity cases v=1m/s, v=5m/s,v=10m/s My Mesh is here : /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (2 0 0) (10 0 0) (10 2 0) (10 4 0) (2 4 0) (0 4 0) (0 2 0) (2 2 0) (2 0 1) (10 0 1) (10 2 1) (10 4 1) (2 4 1) (0 4 1) (0 2 1) (2 2 1) ); blocks ( hex (0 1 2 7 8 9 10 15) (20 20 1) simpleGrading (1 1 1) hex (6 7 4 5 14 15 12 13) (20 20 1) simpleGrading (1 1 1) hex (7 2 3 4 15 10 11 12) (20 20 1) simpleGrading (1 1 1) ); edges ( ); patches ( wall top ( (5 13 12 4) (4 12 11 3) ) wall bottomAndSide ( (1 9 8 0) (7 15 14 6) (8 15 7 0) ) /*patch middle ( (15 12 4 7) () )*/ patch inlet ( (6 14 13 5) ) patch outlet ( (2 3 11 10) (1 2 10 9) ) empty frontAndBack ( (6 5 4 7) (7 4 3 2) (0 7 2 1) (8 9 10 15) (15 10 11 12) (14 15 12 13) ) /* wall side ( (8 15 7 0) )*/ ); mergePatchPairs ( ); // ************************************************** *********************** RAS Properties : /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object RASProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // RASModel laminar; turbulence on; printCoeffs on; // ************************************************** *********************** // Velocity for my first case v=1m/s /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (1 0 0); boundaryField { inlet { type fixedValue; value uniform (1 0 0); } top { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } bottomAndSide { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } // ************************************************** *********************** // Control folder : /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 195; deltaT 0.05; writeControl timeStep; writeInterval 20; purgeWrite 1; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable true; Here I have copy - pasted the main files ,so that you can view my case. But when I ran it couldn't solve... Please let me know, what other changes would be possible... Thank you in advance.. |
November 18, 2011, 09:26 |
#5 | |
Olivier
Rep Power: 17 |
For the error
and set turbulence off in Ras properties regards, olivier |
November 18, 2011, 09:33 |
Anirudh
Rep Power: 14 |
Hello Mr.Oliver
I have made these changes..... div((nuEff*dev(T(grad(U))))) Gauss linear; div((nuEff*dev(grad(U).T))) Gauss linear; I ran it again....the following erros show up : Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model laminar SIMPLE: no convergence criteria found. Calculations will run for 195 steps. Starting time loop Time = 0.05 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 8.60431e-07, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 8.90117e-07, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0793663, No Iterations 4 time step continuity errors : sum local = 0.000476327, global = -1.21272e-19, cumulative = -1.21272e-19 ExecutionTime = 0.02 s ClockTime = 0 s Time = 0.1 smoothSolver: Solving for Ux, Initial residual = 0.64159, Final residual = 0.0526798, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.619704, Final residual = 0.0470176, No Iterations 4 GAMG: Solving for p, Initial residual = 0.232835, Final residual = 0.0199787, No Iterations 3 time step continuity errors : sum local = 0.000714012, global = 9.7964e-19, cumulative = 8.58368e-19 ExecutionTime = 0.02 s ClockTime = 0 s Time = 0.15 smoothSolver: Solving for Ux, Initial residual = 0.188418, Final residual = 0.00856207, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.290141, Final residual = 0.0194256, No Iterations 4 --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 100.795 Specified mass inflow : 2.40552 Specified mass outflow : 0 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 116. FOAM exiting .......!!???? |
November 18, 2011, 09:45 |
Olivier
Rep Power: 17 |
hello,
Try a more diffusive schem like gauss upwind, and initialise with potentialFoam or run with a lower velocity inlet, map the result and run again with bigger velocity. regards, olivier |
November 18, 2011, 14:02 |
Anirudh
Rep Power: 14 |
Hallo Mr.Oliver ,
Finally I ran and I got some solution.But not sure with Post-processing figures(Velocity and pressure ). If you could give me your E-Mail Id here I can send my files to you. Wherein you could look up for what I have done ... Thank you in advance |
January 26, 2012, 10:44 |
#9 | |
wided
Rep Power: 15 |
February 2, 2012, 07:06 |
controlDict Error
#10 |
Rep Power: 15 |
Hi I am new in OpenFoam I am gettin this message
Can somebody help me? Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #6 at twoPhaseEulerFoam.C:0 #7 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #8 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" Floating point exception Thanks, Recep |
February 2, 2012, 07:10 |
controlDict Error
#11 |
Rep Power: 15 |
Hi
I am gettin this message Can somebody help me? Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #6 at twoPhaseEulerFoam.C:0 #7 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #8 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam" Floating point exception Thanks, Recep |
April 23, 2012, 12:15 |
#12 | |
musaddeque hossein
Rep Power: 18 |
http://foam.sourceforge.net/docs/cpp/a03897_source.html the other one is: ftp://ftp.ux.uis.no/uis/x/OpenFOAM/OpenFOAM-1.5.../adjustPhi.C It appears the someone made corrections to the second one -- there is no hardcoded limit on the flux ratio. Can some one verify which one is better and how it can be implemented in the OpenFoam that I have? Thanks. |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
