-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   internal field (http://www.cfd-online.com/Forums/openfoam-pre-processing/100498-internal-field.html)
libia87 April 26, 2012 05:56
internal field
Hi!
I have a cylinder and I want to simulate the concentration.
my problem is: I have the cylinder split in 20 parts and I want to say that 10 volums are C=0.5 and the others 10 volums C=-0.5.
how can I put this in the /0?? becouse in internalField can only be one value ... and I want to specify the volums, not the surfaces
Thanks!
Phicau April 26, 2012 06:04
You can use setFields for that purpose. Check the damBreak tutorial for an example.
Regards
libia87 April 26, 2012 06:36
Regards
ok!!! thanks :)
i have another question, in the example of break damm
defaultFieldValues
volScalarFieldValue alpha1 0
regions
boxToCell
box (0 0 -1) (0.1461 0.292 1);
fieldValues
volScalarFieldValue alpha1 1
what is box (0 0 -1) (0.1461 0.292 1);?? I know that the second parentesis is the coordinates x,y,z , but (0 0 -1) i don't know what it is.
and in my case that i have a cylinder, how can I describe the coordinates if it's cylindrical??
thanks
ybapat April 26, 2012 07:49
For cylinderical region you need to use cylinderToCell.
Phicau April 26, 2012 09:39
All the cells whose center is within a box with lower corner (minX minY minZ) = (0 0 -1) and upper corner (maxX maxY maxZ) = (0.1461 0.292 1) get the alpha1 = 1.
Depending on the geometry of the 20 parts you may need to use cylinderToCell as Yogesh says, or you can continue using boxToCell.
libia87 April 27, 2012 03:08
ok thanks! but in the cylinder the lower corner and de upper corner which numbers I have to put??
the cylinder is split in 20 similar parts, like 20 small cylinders
Phicau April 27, 2012 03:19
cylinderToCell has a different input, 2 points and a radius instead of a box:
p1 (0 -0.08 0);
p2 (0 0.06 0);
radius 0.12;
libia87 April 27, 2012 03:21
defaultFieldValues
volScalarFieldValue p 0
regions
cylinderToCell
cylinder (0 0 0) (0 0 2.5) 1.25;
fieldValues
volScalarFieldValue p 1
with this setFields give me an error, FOAM FATAL IO ERROR: keyword p1 is undefined in dictionary cylinderToCell
what does it mean?
Phicau April 27, 2012 03:24
It asks for word p1, as you have not specified the points:
defaultFieldValues
regions
cylinderToCell
p1 (0 0 0);
p2 (0 0 2.5);
radius 1.25;
fieldValues
libia87 April 27, 2012 03:27
Originally Posted by phicau (Post 357401)
it asks for word p1, as you have not specified the points:
Defaultfieldvalues
volscalarfieldvalue p 0
regions
cylindertocell
p1 (0 0 0);
p2 (0 0 2.5);
radius 1.25;
fieldvalues
volscalarfieldvalue p 1
thanks!!!!! :)
AC87 May 18, 2012 10:18
Hi
i have this error with the tool cylinderToCell
--> FOAM FATAL IO ERROR:
keyword fieldValues is undefined in dictionary "::cylinderToCell"
Can you help me?
range_rover February 4, 2015 04:20
Hi
Can you help me?
check out the spelling of of fieldvalues then
xoitx March 11, 2016 13:12
HI
I get this message after pasting your code to setfeildsdict
Setting field default values
--> FOAM Warning :
From function void setCellFieldType(const fvMesh& mesh, const labelList& selectedCells,Istream& fieldValueStream)
in file setFields.C at line 124
Field p not found
Setting field region values
Adding cells with centre within cylinder, with p1 = (0 0 -0.003), p2 = (0 0 0.003) and radius = 0.003
--> FOAM Warning :
Field p not found (I'm guessing this has to do with p file.. but I have p_rgh??? :O)
End
Can you help please?
martel March 31, 2016 10:57
Originally Posted by xoitx (Post 589227)
HI
--> FOAM Warning :
Field p not found
--> FOAM Warning :
End
Hi Xoitx,
I have the same problem!, Did you find a solution?
Regards,
--Carlos
xoitx March 31, 2016 11:49
Hi Carlos
I solved it using this
// Cells underneath plane such that volume is reached. E.g. for use
// // in setFields to set the level given a wanted volume.
// source targetVolumeToCell;
// sourceInfo
// volume 2e-05;
// normal (0 1 0); // usually in direction of gravity//This is the vector (normal) of the plane
you can find all of the commands and usage here:
openfoam30/applications/utilities/mesh/manipulation/topoSet/
There is a file called topoSetDict
Check it out :D
Regards
Xoitx
martel March 31, 2016 11:53
Originally Posted by xoitx (Post 592694)
Hi Carlos
Check it out :D
Regards
Xoitx
Thanks!
--Carlos
ebtedaei November 11, 2016 05:44
defaultFieldValues
regions
cylinderToCell
p1 (0 0 0);
p2 (0 0 2.5);
radius 1.25;
fieldValues
Hi, I also same error! :
" keyword p1 is undefined in dictionary cylinderToCell "
I introduced keyword p1 !!!
defaultFieldValues
volScalarFieldValue alpha.water 1
regions
cylinderToCell
cylinder
p1 (-0.83261 0.11118 0);
p2 (0.82468 -0.11012 0);
radius 0.03;
fieldValues
volScalarFieldValue alpha.water 0
Please help me.
Ali
ebtedaei November 11, 2016 05:46
Originally Posted by libia87 (Post 357402)
thanks!!!!! :)
Hi, I also have same error! :
I introduced keyword p1 :
defaultFieldValues
regions
cylinderToCell
cylinder
radius 0.03;
fieldValues
Please help me.
Ali
