-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Tutorial cavity mapFields (http://www.cfd-online.com/Forums/openfoam-pre-processing/101547-tutorial-cavity-mapfields.html)
daxindamix May 7, 2012 09:44
I started OpenFOAM tutorial but I'm stuck almost at the beginning. I run the first case "cavity" and I should continue with "CavityFine" with another Mesh definition. In order to keep the calculation already done I should proceed in mapFields but I cannot find where I should write it. Should I create a new file within the system folder or write it in controlDict?
Thx for your help.
lovecraft22 May 7, 2012 10:13
Where you should write what?
daxindamix May 7, 2012 10:17
mapFields ../cavity -consistent
lovecraft22 May 7, 2012 10:18
It's a command. You need to run it from the shell.
daxindamix May 7, 2012 10:22
I installed OpenFOAM 1.5 on windows, there are all the commmands on the right side of the OpenFOAM designer window, including mapFields, but if I right click on it and I click start then it says taht the argument is missing ...
daxindamix May 8, 2012 05:39
I tried to customize the command mapFields (giving the application name the path and the option -consistent) but it does not work, is anyone familiar with this windows version please? :confused:
