buoyantBoussinesqPimpleFoam - Heat capacity on wall BC |
May 11, 2012, 07:25 |
Daniele Vicario
I'm working with buoyantBoussinesqPimpleFoam solver simulating the flow of water in pipes. Is it possible to define the walls as having heat capacity ? This could give a first approximation of how a warmer fluid is going to be cooled (and for how long) flowing in colder pipes. Without using multiple regions solvers, I mean. Thanks,
Daniele Vicario blueCFD2.1 - Windows 7 |
May 11, 2012, 14:09 |
Daniele Vicario
At the moment I'm trying to use groovyBC to create a relation between the temperature of each cell on the walls to the one of closer cell (but not of the walls).
Someone could indicate whether this could be the right (approximate) approach ? Or do I definetely need a multiregion case ? Thanks.
May 13, 2012, 05:02 |
#3 | |
Daniele Vicario
I found a good BC... in CFX . Here enclosed you can see a picture I found on one of its paper (I hope one is allowed to reproduce them here).
The note on this picture is: Quote:
I hope now it's more clear what I'd like to obtain. Is there any possibility to get the same result in OF ? I know the answer is yes but my math capability are a little...rusty . Any help ?
May 14, 2012, 07:09 |
Aurelien Thinat
I'm not sure I understood your question. But if you need a BC with a heat transfer coefficient and an external temperature you already have the BC named "externalWallHeatFluxTemperature" in OF.
The input is [h & T external] OR [q] with q = h * (T external - T internal). |
May 14, 2012, 13:16 |
Daniele Vicario
Thanks Aurelien, It seems what I need.
Unfortunately I don't have it as a BC choice... Code:
--> FOAM FATAL IO ERROR: Unknown patchField type externalWallHeatFluxTemperature for patch type wall Valid patchField types are : 66 ( advective atmBoundaryLayerInletEpsilon buoyantPressure calculated codedFixedValue codedMixed cyclic cyclicAMI cyclicSlip directionMixed empty epsilonWallFunction fan fanPressure fixedFluxPressure fixedGradient fixedInternalValue fixedPressureCompressibleDensity fixedValue freestream freestreamPressure inletOutlet inletOutletTotalTemperature kappatJayatillekeWallFunction kqRWallFunction mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mixed nonuniformTransformCyclic nutLowReWallFunction nutTabulatedWallFunction nutURoughWallFunction nutUSpaldingWallFunction nutUWallFunction nutkAtmRoughWallFunction nutkRoughWallFunction nutkWallFunction omegaWallFunction oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip processor processorCyclic rotatingTotalPressure sliced slip symmetryPlane syringePressure timeVaryingMappedFixedValue totalPressure totalTemperature turbulentHeatFluxTemperature turbulentInlet turbulentIntensityKineticEnergyInlet turbulentMixingLengthDissipationRateInlet turbulentMixingLengthFrequencyInlet uniformDensityHydrostaticPressure uniformFixedValue uniformTotalPressure waveSurfacePressure waveTransmissive wedge zeroGradient ) file: F:/TAPS/CFD/f900buoyw/0/T::boundaryField::walls from line 41 to line 45. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/bmss/OpenFOAM/OpenFOAM-2.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 135. FOAM exiting
May 14, 2012, 13:28 |
Daniele Vicario
Well, I think externalWallHeatFluxTemperature is just for compressible solvers.
Is there any way to have it using buoyantBoussinesqPimpleFoam ?
May 14, 2012, 17:38 |
#7 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Daniele: Quote:
compressible::externalWallHeatFluxTemperature Code:
grep -r 'compressible::' * Best regards, Bruno
May 15, 2012, 00:53 |
Daniele Vicario
Thanks Bruno.
Unfortunately, it still returns the same errror. BTW, my BC is: Code:
walls { type compressible::externalWallHeatFluxTemperature; Ta uniform 300; h uniform 3; // test value value uniform 300; }
May 15, 2012, 05:20 |
Aurelien Thinat
I think I was using this BC with a "BasicRhoThermo" for the fluid. If you are using a BasicPsiThermo it could lead to an error.
Try to use it by modifying a tutorial. If it works, you will have to change the source code or your solver. |
May 16, 2012, 00:45 |
Daniele Vicario
Just a small update.
I checked what's inside externalWallHeatFluxTemperature and basically it's what I need: Code:
00222 forAll (*this, i) 00223 { 00224 if (q[i] > 0) //in 00225 { 00226 this->refGrad()[i] = q[i]/K(*this)()[i]; 00227 this->refValue()[i] = 0.0; 00228 this->valueFraction()[i] = 0.0; 00229 } 00230 else //out 00231 { 00232 this->refGrad()[i] = 0.0; 00233 this->refValue()[i] = KDelta[i]*q[i] + patchInternalField()()[i]; 00234 this->valueFraction()[i] = 1.0; 00235 } 00236 } So, based on the direction of the Heat flux (q), externalWallHeatFluxTemperature sets the right BC. In order to reproduce this behavior I used groovyBC in this way: Code:
walls { type groovyBC; value uniform 300; gradientExpression "gradT"; fractionExpression "0"; variables "Text=300;hc=10000;gradT=(Text-T)*hc;"; timelines (); } - I'm just considering an entering flux. - I still have to understand what physical value has hc (normally, heat transfer coefficient). In my BC it groups K too, that I think it rappresent specific heat. - hc=10000 is just a test value. Any comment or suggestion would be helpfull, thanks.
November 20, 2012, 04:41 |
#11 |
Romain
I have some problem with externalWallHeatFluxTemperature which is not working properly with OF2.1.0 I can not switch to OF211 because GroovyBC is not working with this new version. Thus, I tried to replace externalWallHeatFluxTemperature with a groovy boundary condition. Code:
walls { type groovyBC; value uniform 300; gradientExpression "gradT"; fractionExpression "0"; variables "Text=300;hc=10000;gradT=(Text-T)*hc;"; timelines (); } I was also using wallexternalHF as an entering heat flux. Could it be also done with groovyBC ? |
December 17, 2012, 03:06 |
#12 |
Paula
Syntax errors with Thread Types and Wall Heat Transfer calculation | jcespada | Fluent UDF and Scheme Programming | 2 | March 16, 2012 02:23 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
how to impose experimental dat as boundary conditi | Rogerio Fernandes Brito | FLUENT | 14 | November 25, 2008 05:47 |
