-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   [Problem] paraFoam Throws volVectorField Error At t=0 for 0/U (http://www.cfd-online.com/Forums/openfoam-pre-processing/101943-problem-parafoam-throws-volvectorfield-error-t-0-0-u.html)
iamed18 May 17, 2012 15:08
1 Attachment(s)
Hey Everyone,
I'm attempting a modification of the incompressible/icoFoam/cavity tutorial in which the "moving wall" still moves [at (10 0 0)], but it also has an inlet in the middle with value (0 -20 0). I've modified the mesh slightly as well, but that's not where my question lies.
After building my mesh and creating my 0/* files, I opened paraFoam just to see the grid and to assure myself that it looked correct. Upon clicking "Apply", paraFoam throws the following error (assume $THIRD_PARTY is where I've installed my ThirdParty-2.1.0 packages):
ERROR: In $THIRD_PARTY/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6637
vtkOpenFOAMReaderPrivate (0xfc193a0):
$CASE/0/U is not a valid volVectorField
Now icoFoam ran just fine and the simulation ended up working (more/less...that's a topic for a different post), but every time I open paraFoam to look at the results, it complains about U not being a valid volVectorField. So, I've got U on display here:
U:
internalField  uniform (0 0 0);
boundaryField
    movingWalls
        type            fixedValue;
        value          uniform (10 0 0);
    airBorders
        type            pressureInletOutletVelocity;
        value          uniform (0 0 0);
    theInlet
        type            fixedValue;
        value          (0 -20 0);
    frontAndBack
        type            empty;
Does anyone have any insight on this? My only idea is that paraFoam doesn't like the type pressureInletOutletVelocity, but beyond that I don't know. I've also attached my blockMeshDict because I'm not sure if the two aren't fully agreeing.
Thanks in advance for any kind of assistance!
~Ed
kmooney June 1, 2012 09:57
Originally Posted by iamed18 (Post 361725)
Hey Everyone,
U:
boundaryField
    movingWalls
        type            fixedValue;
    airBorders
    theInlet
        type            fixedValue;
        value          (0 -20 0);
    frontAndBack
        type            empty;
~Ed
It might be that the theInlet entry is missing a 'uniform'. Instead of this:
    theInlet    {        type            fixedValue;        value          (0 -20 0);    }
Try this:
    theInlet    {        type            fixedValue;        value    uniform      (0 -20 0);    }
iamed18 June 4, 2012 13:15
Alas, I had missed that! Thank you!
Shanmukhi April 11, 2016 10:03
Same problem
I had the same error when I am running in the paraview..
ERROR: In /home/openfoam/OpenFOAM/ParaView-4.4.0//VTK/IO/Geomtry /vtkOpenFOAMReader.cxx, line 6649 vtkOpenFOAMReaderPrivate (0xfc193a0):
Can any1 help me out with this..
Here is the code I am attaching
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U; // This is the fluid velocity at the various boundaries
dimensions [0 1 -1 0 0 0 0];
boundaryField
outlet1
type inletOutlet;
inletValue (0 0 0);
value (0 0 0);
outlet2
type inletOutlet;
inletValue (0 0 0);
value (0 0 0);
inlet
type fixedValue;
value uniform (0.719 0 0);
walls
type fixedValue;
topBottom
type fixedValue;
