Home > Forums > OpenFOAM Pre-Processing
Using lookuptables in momentumSourceDict with swak4Foam
Like Tree2Likes
Old   October 10, 2013, 12:43
Assistant Moderator
Bernhard Gschaider
Originally Posted by alighaffari View Post
Hello Bernhard
Do you have any tutorial or example that teach me how to define a source term from solving a PDE and how to apply it to interFoam solver. If could kindly send me any example related to this field it will be very helpful for me.
Regards
Ali Ghaffari
There isn't a ready-made example for this (and I can't guarantee that it will work for you): examples for using the PDF-functionObjects are (amongst others) in Examples/groovyBC/pulsedPitzDaily. The solution field can then be used like any other field in the expressions of the source term
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 27, 2013, 11:07
Default Create a new field from an expression
  #22
alighaffari
alighaffari is on a distinguished road
Hi Dear Bernhard
thanks for your posts, replies and "swak4Foam". I could solve a PDE using "solveLaplacianPDE" function But I have another question on the "expessionField" function. I am trying to create and calculate a new transformed velocity field using this function. I followed ,for starting, the example available in slides on swak4Foam (No C++, please. We’re users!, Bernhard F.W. Gschaider, June 2011, slide number 61/176):
libs (
" libswakFunctionObjects .so"
functions (
liquidVel
type expressionField;
outputControl outputTime;
//outputInterval 1;
fieldName Uliquid;
expression "U*alpha1";
autowrite true
but it does not work and OpenFoam gives the following error:
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.x-0cbac23c1af5
Exec : interFoamWithSources
Date : Oct 27 2013
Time : 17:53:21
Host : "ali-pc"
PID : 2918
Case : /home/ali/OpenFOAM/ali-2.1.x/run/Afkhami2008/cylinder-radius0.2-sourceterm-PDE
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Calculating field g.h
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/ali/OpenFOAM/ali-2.1.x/run/Afkhami2008/cylinder-radius0.2-sourceterm-PDE/system/controlDict::functions at line 88.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
I have created the "Uliquid" file in the "0" folder based on the "U" file. I have no idea on this error message.
I'm Looking forward to some directions. your valuable time is highly appreciated.
thanks,
Ali Ghaffari
alighaffari is offline   Reply With Quote
Old   October 28, 2013, 05:13
Nima Samkhaniani
nimasam is on a distinguished road
you missed semicolon in your expression, it should be like that:
expression "U*alpha1;";
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   October 28, 2013, 10:23
alighaffari
Hi Dear Nima Sam
thanks for your reply. I modified it by semicolon But again exactly the same error message appears. What else may be wrong?
thanks
Old   October 28, 2013, 19:25
Assistant Moderator
Bernhard Gschaider
Hi Dear Nima Sam
thanks
Which is line 88 in your controlDict (that is the one that is mentioned in the error message you quoted. I must stress that this message means that your file is syntactically wrong. swak hasn't even seen it yet)
Is it maybe the line "autowrite true" without the semicolon?
Old   October 29, 2013, 10:52
alighaffari
Hi Dear Bernhard Gschaider
yes it was the reason for error : "autowrite true" without the semicolon. thanks so much.
Old   November 4, 2013, 12:07
alighaffari
Its me again with another question. I have calculated the magnitude of the gradient of a scalar field in two ways:
1) by using the "magGrad" from "foamCalc" utility:
foamCalc magGrad distance
2) by defining a new Field in "controldict" file:
functions(
distGrad {
outputControl timeStep;
outputInterval 1;
fieldName graddistance;
expression "-grad(distance)";
autowrite true;
and finally I have calculated the magnitude of the new field "graddistance".
("distance" is a new scalar field which is calculated from solving the Laplaces equation via "solveLaplacianPDE" function.)
But the results are very much different (in order of 1000000). It is so strange and confusing for me. Which way is more reliable?
I need the gradient of "distance" in the solution time. Is there any better method for its calculation?
Thank you
Regards
Old   November 4, 2013, 12:19
Assistant Moderator
Bernhard Gschaider
functions(
distGrad {
outputInterval 1;
autowrite true;
Thank you
Regards
Could you check WHERE these differences occur? For instance by calculating the diff between the two fields with funkySetFields? My guess is that the difference is in boundary cells
Old   November 5, 2013, 10:05
alighaffari
the difference is all over the solution domain. It seems that the results from magGrad function from "foamCalc" are true. But I need the gradient over the solution time. What can I do? Is there any other Method?
Old   November 8, 2013, 18:31
Assistant Moderator
Bernhard Gschaider
That's strange. "mag(grad(T))" in swak uses the same functions as magGrad. I think I need to see pictures of the differences to tell what might be the problem
Old   November 9, 2013, 10:18
alighaffari
Thanks for your attention. I could finally find the reason of the differences. It was due to the "writePrecision" in the controlDict file. The differences were existed when the default value ,6, was chosen. But by increasing the "writePrecision" the differences decreased. finally no differences were observed by choosing the "20" for "writePrecision". I think that the "magGrad" function from "foamCalc" reads the data from written results files But the "grad" function from "swak" reads data from RAM. Please correct me if I am wrong?
thanks
Ali
nimasam likes this.
Old   November 9, 2013, 20:08
Assistant Moderator
Bernhard Gschaider
thanks
Ali
Depends. funkySetFields reads from disc. But the function Objects use the field from memory.
So that problem solved itself? Fine.
Thread Tools
Trackbacks are On
groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM 164 January 13, 2015 03:52
Problem to calculate grad(U) using swak4Foam Hugoles OpenFOAM Post-Processing 11 September 25, 2014 19:07
swak4foam callahance OpenFOAM 28 August 4, 2013 11:40
Swak4foam: get the value of a field in the neighbour cell of a patch face miles_davis OpenFOAM Pre-Processing 7 October 5, 2011 11:57
swak4Foam for faceZones andrea.pasquali OpenFOAM 3 August 30, 2011 11:24
