Orientation of faceZone, mass flow sign convention
Old   June 27, 2016, 23:53
Angry Orientation of faceZone, mass flow sign convention
Florian Nguyen
Awak is on a distinguished road
I am going to ask a question which is going to seem very basic, but you will understand my doubt when I explain.
I am modelling two tanks with 1.0 atm / 0.2 atm connected to each other by a reed valve. I want to measure the mass flow pouring from the high pressure tank to the low pressure tank. For this I use rhoCentralFoam (OF3.0+).
I defined my mesh using blockMesh and SNM, and a faceZone that I use for mass flow estimation. The "faceSet" picture shows the aspect of the faceZone. I checked visually that this face does not have any defects, like unwanted faces. Here is how I defined this face.
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object topoSetDict;
actions
// Creation of faceSet
name inletFaceSet;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (0.010 -0.010 0.00099) (0.1 0.010 0.00101);
// Creation of faceZone from previous faceSet
name inletFace;
type faceZoneSet;
action new;
source setAndNormalToFaceZone;
sourceInfo
faceSet inletFaceSet;
normal (0 0 1);
I did not detect any anomaly in the pressure or velocity fields during the simuation, especially regarding the direction of velocity.
HOWEVER...
For some reason, when I gradually refine my mesh to check for mass flow convergence, the outputed mass flow's sign, especially the stationary value, is changing sign! It does not make sense to me, because I don't see any such "change" in the velocity and pressure fields. The "velocityAtFace" picture shows the global trend for the velocity field (face is coloured with pressure, arrows according to velocity). This trend is the same for any other refinement level.
My face is defined with a normal (0 0 1). According to the initial pressure difference existing between the tanks, I am expecting a velocity in -Z direction, so a negative mass flow through my face? In that case, I would like to understand why I have positive mass flow values for lower refinement levels and negative values for higher refinement, even if the velocity field appears not to be altered.
My case is available temporarily at: https://drive.google.com/file/d/0B0k...ew?usp=sharing
If you want to see for yourself, just change the refinement levels of regions from 5 to 2 or 0.
Any help would be greatly appreciated, thanks to you all,
Florian
Awak is offline   Reply With Quote
Old   June 28, 2016, 09:40
Default EDIT: Found something rather strange
Florian Nguyen
EDIT:
I cut a 2D slice at the location of the faceSet used for mass flow calculation, and plotted the velocity glyph. The velocity field looks perfectly fine:
Screenshot from 2016-06-28 22:04:34.jpg
Looking from above to this slice, the velocity field looks like this:
Screenshot from 2016-06-28 22:10:27.jpg
Now here comes the funny stuff... I put "valueOutput true;" to export the mass flow field in a VTK file at was looks to be steady state judging from the velocity field, and here is what mass flow distribution looks like on my faceZone:
Screenshot from 2016-06-28 22:14:13.jpg
This is rather confusing... I checked my faceZone before running the solver, so I really don't see what I am doing wrong. Could I have your lights please?
Old   August 1, 2016, 21:28
Florian Nguyen
Solved by constraining the cells by means of an AMI... Hope this will be useful to some of you.
Florian
Mass flow discrepancy BenMUC CFX 3 May 2, 2014 03:29
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
Mass flow rate through each cell Babakjingo Main CFD Forum 0 August 21, 2011 03:18
mass flow Wenbin Song FLUENT 0 September 27, 2005 13:00
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
