select disk with faceSet
Old   June 7, 2012, 10:20
Default select disk with faceSet
raffale is on a distinguished road
Hi everyone,
This is my first thread but I already spent a lot of time to read yours threads. This forum is a blessing for every new user of Openfoam like me.
So this is my case, I want to simulate the landing of an helicopter in aerodynamic corridor disrupted by structures. I chose to model the rotors with actuator disks.
I used snappyHexMesh for create my Mesh (helicoptere without rotors + ground structures) and I use toposet and createBaffles to create my rotors. Then I use type fan BC for my rotors.
My problem: In my toposet I only know create rectangular rotor with these lines:
actions
name cyclicfanFaces;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (13 -1.5 9.4) (16 1.5 9.6);
name cyclicfanFacesSlaveCells;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (13 -1.5 9.5) (16 1.5 13);
name cyclicfanZoneFaces;
type faceZoneSet;
action new;
source setsToFaceZone;
sourceInfo
faceSet cyclicfanFaces;
cellSet cyclicfanFacesSlaveCells;
And I Want to select a DISK rotor, because a rotor is a disk. I think this problem is boxToFace in faceSet but I don't know what other faceSet keyword choose.
With CellSet we can use cylinderToCell but with faceSet it's not possible.
So have you suggestions to solve that simple but annoying problem.
Thanks ahead for your comments
Regards,
Cyril
PS: Don't hesitate to correct my english. I must improve my writing skills.
raffale is offline   Reply With Quote
Old   June 7, 2012, 11:08
Disabled
anon_a is on a distinguished road
If you take a look in
applications/utilities/mesh/manipulation/topoSet/topoSetDict
you can see various functions that you can use to select cells/faces/points.
Something that you could do perhaps is a cylinderToCell to select cells on both sides of the wanted faces and then cellToFace with the option "both".
Assuming off course that your faces are appropriately shaped and positioned to create a perfect disk.
anon_a is offline   Reply With Quote
Old   June 7, 2012, 15:24
Thanks for your reply anon_a, I'll take a look tomorrow.
After reading the post on the forum and after taking a look on the tutorial with "type fan BC"(Tjunctionfan), I found it strange that in these cases the actuator disk was modeled by a rectangular surface and never with disk.
What a pity that cylinderToFace doesn't exist in OpenFoam. This would be so much easier.
Regards,
Cyril
Old   June 7, 2012, 17:37
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Regards,
Cyril
At least you can spare yourself the trouble of programming your own topoSource with the expressionToFace topo-source that comes with swak4Foam. Something like
expression "mag(pos().z)<1 && sqrt(pow(pos().x,2)+ pow(pos().y,2))<1"
will select all faces on the boundary of a cylinder
expression "mag(fpos().z)<1 && sqrt(pow(fpos().x,2)+ pow(fpos().y,2))<1"
will select all faces INSIDE the cylinder
gschaider is offline   Reply With Quote
Old   June 8, 2012, 08:27
It works! Thanks for yours replies, it was helpful.
Here is my toposet if someone want to select a disk:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
name c0;
type cellSet;
action new;
source cylinderToCell;
sourceInfo
//box (12.5 -2 9.5) (16 2 13);
p1 (14.5 0 9);
p2 (14.5 0 11);
radius 3.4;
type faceSet;
action new;
source cellToFace;
sourceInfo
set c0;
option both;
name c1;
type cellSet;
action new;
sourceInfo
p1 (14.5 0 10);
p2 (14.5 0 11);
radius 3.4;
name f1;
type faceSet;
action new;
source cellToFace;
sourceInfo
set c1;
option both;
name c2;
type cellSet;
action new;
sourceInfo
p1 (14.5 0 9);
p2 (14.5 0 10);
radius 3.4;
name f2;
type faceSet;
action new;
source cellToFace;
sourceInfo
set c2;
option both;
type faceSet;
action delete;
source faceToFace;
sourceInfo
set f1;
type faceSet;
action delete;
source faceToFace;
sourceInfo
set f2;
It's a succession of boolean operations.
Regards,
Cyril
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
actuator disk Atit CFX 9 July 26, 2016 09:39
[swak4Foam] Mass flow rate through faceSet using swak4foam CedricVH OpenFOAM Community Contributions 5 May 4, 2012 07:57
Actuator Disk Model sujialin CFX 0 April 18, 2010 16:29
Modelling an actuator disk in FLUENT teymourj Main CFD Forum 0 April 28, 2009 21:42
