-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Error after typing blockMesh (http://www.cfd-online.com/Forums/openfoam-pre-processing/103959-error-after-typing-blockmesh.html)
fshak92 June 30, 2012 06:44
Hello
Typing "blockMesh" the "blockMeshDict" folder of both the tutorial "cavity" and "pitzDayly" gives me these errors in spite of having controlDict in the system folder:
file: /home/omid/OpenFOAM/omid-2.1.1/run/tutorials/incompressible/icoFoam/cavity/constant/polyMesh/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
I would appreciate if anyone has an idea or suggestion regarding the mentioned error.
wyldckat June 30, 2012 07:08
Hi omid88,
You're meant to run the command from within the case's root folder, not from within the "polyMesh" folder ;)
Best regards,
Bruno
