Setting side/wedge boundary condition
Like Tree2Likes
  • 1 Post By Thoma
  • 1 Post By zhixuan
Old   August 1, 2012, 23:12
Default Setting side/wedge boundary condition
Thomas S
Thoma is on a distinguished road
I am trying to set a proper boundary condition for sidewalls. To illustrate my problem, I have attached a screenshot.
The problem is to set boundary conditions on the green parts in the picture. I'd like to apply identical conditions for both sides. So for instance, flow stream leaving one side should enter the volume on the other side.
I think some kind of 'wedge' boundary condition is most convenient but I haven't managed it so far.
Is it possible to do it with wedge conditions? Or are there any more convenient?
I am using Salome for meshing.
Thanks for your help.
Thoma
Thoma is offline   Reply With Quote
Old   August 22, 2012, 00:49
Thomas S
Ok. I managed it by using cyclicAMI which is available since OpenFoam v2.1.0
http://www.openfoam.org/version2.1.0/
Here you don't need exact matching points on both sides. Nevertheless a similar meshing is required. To mesh it with Salome see here:
http://www.salome-platform.org/forum/forum_10/272693881
Finally my boundary file looks like this:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
6
inlet
type patch;
nFaces 350;
startFace 125878;
outlet
type patch;
nFaces 342;
startFace 126228;
side1
type cyclicAMI;
neighbourPatch side2;
transform translational;
separationVector (-0.04 0 0);
nFaces 1478;
startFace 126570;
side2
type cyclicAMI;
neighbourPatch side1;
separationVector (0.04 0 0);
nFaces 1478;
startFace 128048;
wall
type wall;
nFaces 4431;
startFace 129526;
vane
type wall;
nFaces 981;
startFace 133957;
I hope this helps anyone who struggles with a similar problem I had.
regards,
Thomas
Ramzy1990 likes this.
Old   February 20, 2013, 17:00
Peter Skrifvars
Skrifvars is on a distinguished road
Hi Thoma,
You mentioned
'Nevertheless a similar meshing is required.'
Does this mean that you had to reorder the coupled faces in some manner that I don't
find in Salome or OF applications ?
Did you create this cyclicAMI with createPatch or just by editing the boundary file ?
BR
Peter
Skrifvars is offline   Reply With Quote
Old   February 20, 2013, 17:32
Thomas S
Hi Peter.
you have to copy the mesh information from one side to the other. Follow the link I have posted above. There it is sxplained.
I didn't use createPatch. Just edited the boundary file.
Regards, Thomas
Old   July 15, 2014, 19:06
Default transform type
ZD
zhixuan is on a distinguished road
hi all,
I tried the processes above on my simulation using OF2.3. However, there is some problems.
My case is a quarter of a cylinder. So the two section planes should be defined as cyclic BC. At beginning, I thought I should set the transform type to be "rotational" according this link.
However, this setup causes a rotation of the entire flow field.
Now, I think I should use the type of "translational". I set the separationVector to be the Z axis (0 0 1). But it reports errors as follows:
Create time
Create mesh for time = 0
Reading field p
--> FOAM Warning :
From function polyBoundaryMesh::groupPatchIDs() const
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 461
Patch bottom specifies a group wall which is also a patch name. This might give problems later on.
--> FOAM Warning :
Patch wall specifies a group wall which is also a patch name. This might give problems later on.
AMI: Creating addressing and weights between 3320 source faces and 3320 target faces
--> FOAM Warning :
From function AMIMethod<SourcePatch, TargetPatch>::checkPatches()
in file lnInclude/AMIMethod.C at line 57
Source and target patch bounding boxes are not similar
source box span : (0.07875 4.82189e-18 0.5105)
target box span : (3.61641e-18 0.07875 0.5105)
source box : (0 0 0) (0.07875 4.82189e-18 0.5105)
target box : (-2.41094e-18 0 -1) (1.20547e-18 0.07875 -0.4895)
inflated target box : (-0.0258269 -0.0258269 -1.02583) (0.0258269 0.104577 -0.463673)
So I'm wondering if there is anyone can kindly provide any hints regarding this issue.
Thank you
Hemishmistry04 likes this.
zhixuan is offline   Reply With Quote
Setting the inlet boundary condition with inclination saisanthoshm88 CFX 1 October 4, 2011 07:41
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
boundary condition velocity inlet dont have gauge pressure setting value? coolyihao FLOW-3D 0 March 17, 2009 11:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
