September 18, 2012, 09:50 |
Axisymmetric Whirl BCs; Wedge or Cyclic?
Cameron
Hi all
I'm attempting to model a buoyancy driven whirling flow (about the z axis) using an axisymmetric mesh. To do this I have generated a 5 degree wedge straddling the x axis using block mesh, and defined the wedge walls as "wedge" types. My inlet conditions are fixed velocities at the outer edge of this wedge (the outside of the cylinder), specifying an x and y component. My issue is that when I view the results, my y velocity is not being generated at the boundary, rather a much smaller value going in opposite directions on either face (instead of the same direction). Is this because the wedge patch type is intended only for axisymmetric problems with no flow through the wedge faces? To fix this I've also tried using cyclic patches, which gives me the correct y component velocity however makes the x velocity behave strangely, specifically having slightly different (yet significant) values on each wedge face. My question is, is there a better way of specifying the velocity inlet on the outer edge of a wedge shaped mesh to avoid this? Also, I was under the impression that the axisymmetric mesh would be solved similar to a 2d problem, if this is true though why do I get slightly different velocity values on each wedge face? I'm still new to this so I feel it's likely to be something obvious i've overlooked. |
September 18, 2012, 13:10 |
#2 | |
Niels Nielsen
Rep Power: 27 |
As you say you need to use cyclics and I would recommend that you use at leas 10 cells in the circumferential direction.
Linnemann PS. I do not do personal support, so please post in the forums. |
September 18, 2012, 19:32 |
Cameron
Ahh thanks a lot, what kind of angle should my mesh describe? At the moment i've got it at 22.5 degrees and it seems to be running okay. Thanks again for the help.
September 19, 2012, 08:48 |
Niels Nielsen
Rep Power: 27 |
Hi
22.5 is a fine number in my opinion, but this is of course something you can play with to see if you get consistent results.
December 5, 2012, 10:38 |
Matthias
Hey Cameron,
I have a similar problem as you had - flow through the wedgefaces should be possible... Which changes did you have to do for the switch from wedge to cyclic? (I'm a OF-beginner) Thank you so much! Matthias |
axisymmetric mesh, axisymmetric swirl, boundary conditions |
Symmetryplane, cyclic and wedge boundary conditions | Taltan | OpenFOAM Pre-Processing | 7 | April 18, 2023 11:31 |
How to setup cyclic BCs in simpleFOAM | hhuang84 | OpenFOAM Running, Solving & CFD | 14 | December 8, 2016 11:39 |
axisymmetric wedge case problem | comedy_tigers88 | OpenFOAM Running, Solving & CFD | 0 | June 16, 2012 04:45 |
Adjusting velocity using cyclic bc's | gregdB | Main CFD Forum | 0 | January 25, 2012 09:08 |
Cyclic BCs using createPatch in OF 1.6.x | SunnyPP | OpenFOAM | 2 | August 6, 2010 10:21 |
