postprocessing with sample in a cyclic case and multiregion fail
Old   September 27, 2012, 04:13
Default postprocessing with sample in a cyclic case and multiregion fail
Sebastian
sebware is on a distinguished road
hallo
i had developed a well working postprocessing with sample in a case with 3 coupled regions.
now i have changed two boundarys to cyclic. Everything works fine, but if i try to use the same sampleDict i get errors.
i have tried sample from the of1.6ext version and from the of21 version as well.
Must i write a special entry in the sampleDict to handle cyclic cases ??
The of21 version gives up with the following error
Create mesh fluid for time = 0.4
--> FOAM FATAL IO ERROR:
No "neighbourPatch" provided.
Is your mesh uptodate with split cyclics?
Run foamUpgradeCyclics to convert mesh and fields to split cyclics.
file: ::sidePatches from line 31 to line 36.
    From function cyclicPolyPatch::cyclicPolyPatch
    const word& name,
    const dictionary& dict,
    const label index,
    const polyBoundaryMesh& bm
    in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 681.
FOAM exiting
thanks for helping
best regards
Sebastian
sebware is offline   Reply With Quote
cyclic, regions, sample
how to create an internal fan for a multiRegion case? phsieh2005 OpenFOAM 0 February 2, 2012 16:32
Basic hints for runing a multiregion case RuiVO OpenFOAM Pre-Processing 1 February 2, 2012 09:44
