variable pressure at the output of a manifold
Old   September 26, 2012, 12:11
Default variable pressure at the output of a manifold
Joe
shackur is on a distinguished road
I'm actually simulating a car intake manifold. I've solved it with constant BC, but I would like to do it with a variable outlet pressure as an engine aspiration.
Is there any function simulating an engine aspiration or something to define a variable output pressure? I guess there is something to do that, I've find things but they didn't clearly solve my needs or explain how to use them.
I'm sorry, I'm new in OpenFOAM and I just know how to use basic solvers
If that helps, I've done the mesh with snappyHexMesh and solved as an incompressible flow (pisoFoam). I just know inlet and outlet pressure (wich is variable), but not velocity, I've solved the initial velocity conditions with potentialFoam
Thank you very much.
regards
shackur is offline   Reply With Quote
variable pressure
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Variable outside pressure Neser25 CFX 9 June 5, 2006 12:37
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
