October 12, 2012, 13:08 |
decomposePar segfault
Jutta Adelsberger
I got a segmentation fault using decomposePar. Usually, decomposePar works fine but in this case I receive Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : decomposePar Date : Oct 12 2012 Time : 17:56:02 Host : "" PID : 20264 Case : /... nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Time = 0 Create mesh Calculating distribution of cells Selecting decompositionMethod simple Finished decomposition in 0.21 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes #0 Foam::error::printStack(Foam::Ostream&) in "/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 in "/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/decomposePar" #4 in "/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/decomposePar" #5 in "/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/decomposePar" #6 __libc_start_main in "/lib/libc.so.6" #7 in "/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/decomposePar" Segmentation fault Code:
Starting program: /mnt.auto/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/decomposePar [Thread debugging using libthread_db enabled] /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : /mnt.auto/opt64/packages/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/decomposePar Date : Oct 12 2012 Time : 17:56:31 Host : "" PID : 20304 Case : /... nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Time = 0 Create mesh Calculating distribution of cells Selecting decompositionMethod simple Finished decomposition in 0.22 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Program received signal SIGSEGV, Segmentation fault. 0x0000000000531882 in Foam::domainDecomposition::mark(Foam::List<int> const&, int, Foam::List<int>&) () (gdb) bt #0 0x0000000000531882 in Foam::domainDecomposition::mark(Foam::List<int> const&, int, Foam::List<int>&) () #1 0x000000000053348b in Foam::domainDecomposition::writeDecomposition() () #2 0x000000000045da0e in main () (gdb) Jutta |
October 17, 2012, 12:50 |
Kevin Smith
Hi Jutta,
You might try using the latest 2.1.x version to see if any bug has been fixed since your 2.1.0 build. If that still fails, you could post your mesh here, and/or submit a bug report to opencfd. Kevin |
decomposePar gives errors | of_user_ | OpenFOAM | 1 | July 4, 2011 06:27 |
checkMesh and decomposePar crashes with salome IDEAS mesh | pajofego | OpenFOAM | 0 | June 23, 2011 09:43 |
decomposePar: can use this decomposition method only for the whole mesh | aloeven | OpenFOAM Bugs | 0 | March 16, 2011 11:15 |
Strange behaviour 1.6 decomposePar vs 1.7 decomposePar | BlueyTheDog | OpenFOAM | 7 | January 16, 2011 19:12 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
