June 18, 2019, 06:57 |
Mapping two patches
Zander Meiring
Rep Power: 7 |
Good day,
I am trying to map information between two patches. I am making use of OF1806 using simpleFoam and a MRF solver. Attached is an illustration of the problem (not my actual mesh) The blue line represents one patch, and the red line the other. The meshes are non-confromal so I would like to make use of something such as cyclicAMI zeroOrdering to map from one to the other. The areas where A and B overlap, it must simply transfer information (act as internal faces) but region C must act as a wall (zero U, zeroGrad p, etc) as there is no patch to transfer information to. Unfortunately my problem is 3d and quite difficult to mesh conventionally, so I am hoping to achieved the desired effect with this. Is this possible? and if so, what tools will I need? any help would be massively appreciated, thanks! Regards, Zander Meiring |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
