directionalKSolidThermo syntax
Like Tree3Likes
Old   August 3, 2012, 10:38
Default directionalKSolidThermo syntax
m_f
M
m_f is on a distinguished road
I'm trying to create an orthotropic material, with an orthotropic conductivity. So, i try to use the directionalKSolidThermo function with this syntax :
directionalKSolidThermoCoeffs
    //- does interpolation and directional K in coordinate system.
    //  Specify multiple values, one for each temperature. Properties are
    //  interpolated according to the local temperature.
    //- thermo properties
    TValues             (100 1000);
    rhoValues           (1700 1700);
    cpValues            (1700 1700);
    KValues             ((10 10 1) (10 10 1));
    coordinateSystem
        origin  (0 0 0);
        coordinateRotation
            type    axes;
            e1      (1 0 0);
            e2      (0 1 0);
            e3      (0 0 1);
    //- chemical properties
    HfValues            (0 0);
    //- radiation properties
    emissivityValues    (0.95 0.95);
    kappaValues         (0 0);
    sigmaSValues         (0 0);
But it doesn't work...
That's the error :
--> FOAM FATAL ERROR:
Not implemented
    From function directionalKSolidThermo::K(const label) const
    in file directionalKSolidThermo/directionalKSolidThermo.H at line 134.
FOAM aborting
Any idea about where the mistake is ?
Thank you for any hint.
Excuse my english
Best Regards, m_f
m_f is offline   Reply With Quote
Old   August 10, 2012, 08:45
Nikola
MarkWithag is on a distinguished road
I am facing with the same problem.
Did you find any solution?
Thanks.
MarkWithag is offline   Reply With Quote
Old   August 10, 2012, 13:44
Retired Super Moderator
Bruno Santos
Greetings to all!
What version of OpenFOAM are you using?
And can you attach an example case? This way it'll be easier for people here at the forum to help you!
Best regards,
Bruno
Old   August 10, 2012, 16:35
Nikola
Hi Wyldckat,
I am using openfoam211.
I have problem to attached this file but this file can be find following the next path in openfoam211:
tutorials/heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater/constant/heater/solidThermophysicalProperties.
I changed feature "thermoType constSolidThermo" to "thermoType directionalKSolidThermo" which was already inside.
If this feature is not technically implemented yet could you tell me how I can model directional conductivity in solid. For instance, K=0 in x-direction, K=17 in y-direction and K=17 in z-direction?
Thank you in advance.
Regards,
Nikola
Old   August 10, 2012, 18:39
Bruno Santos
Hi Nikola,
I'm stumped... apparently this feature is broken! It was sort-of fixed here: http://www.openfoam.org/mantisbt/view.php?id=438
But technically it only delegates the problem down the line... but I can't understand if there is any derived class that reimplements this method
I've checked OpenFOAM 2.1.0, 2.0.x, 1.7.x and even the variant 1.6-ext, and it doesn't look like it will work in either one of the them... actually, in 1.7.x and 1.6-ext, this case isn't even implemented in the same way
I guess I'm only able to suggest the thing you where earlier thinking: this is a bug! But this should be reported here: http://www.openfoam.org/mantisbt/my_view_page.php
Please describe there the same steps you've described here.
Best regards and good luck!
Bruno
Old   August 11, 2012, 09:14
m_f
M
As MarkWithag :
I do approximately the same case, with the same version of OpenFOAM. I'm a bit disappointed by answers, but thank you, we are all fixed now.
The bug was reported by MarkWithag. Please follow this link : http://www.openfoam.org/mantisbt/view.php?id=622
Best regards. Have a good week-end.
m_f
Old   August 15, 2012, 02:54
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
I think I know what the problem is.
you are trying to access a scalar-valued K, which is not defined for the tensor approach.
If you go to the code
applications/solvers/heatTransfer/chtMultiRegionFoam/solid/setRegionSolidFields.H
you will see that K is defined as a scalar
tmp<volScalarField> tkappa = thermo.K();
const volScalarField& kappa = tkappa();
//tmp<volSymmTensorField> tkappa = thermo.directionalK();
//const volSymmTensorField& kappa = tkappa();
if you uncomment the tensor-part and comment the scalar part and recompile the code
and try to run your case what will happen then.
N
wyldckat likes this.
niklas is offline   Reply With Quote
Old   August 15, 2012, 05:23
Bruno Santos
Hi Niklas,
I was curious and tried this myself. The same error message came out
Here's a more complete output:
Region: bottomAir Courant Number mean: 0.002118344 max: 0.003438382
Region: topAir Courant Number mean: 0.02267985 max: 0.03164373
Region: heater Diffusion Number mean: 2.495128e-06 max: 3.140529e-06
Region: leftSolid Diffusion Number mean: 2.499425e-06 max: 3.038856e-06
Region: rightSolid Diffusion Number mean: 2.499393e-06 max: 3.040031e-06
deltaT = 0.009475679
Region: bottomAir Courant Number mean: 0.02007275 max: 0.032581
Region: topAir Courant Number mean: 0.214907 max: 0.2998459
Region: heater Diffusion Number mean: 2.364303e-05 max: 2.975865e-05
Region: leftSolid Diffusion Number mean: 2.368375e-05 max: 2.879523e-05
Region: rightSolid Diffusion Number mean: 2.368345e-05 max: 2.880636e-05
Time = 0.00947568
Solving for fluid region bottomAir
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 5.185517e-10, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 8.709587e-11, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 5.069313e-10, No Iterations 3
Got here 00.
Not implemented
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::directionalKSolidThermo::K(int) const in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libbasicSolidThermo.so"
#3  Foam::temperatureCoupledBase::K(Foam::Field<double> const&) const in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#4  Foam::compressible::turbulentTemperatureCoupledBaffleMixedFvPatchScalarField::updateCoeffs() in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#5  Foam::mixedFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6  Foam::mixedEnthalpyFvPatchScalarField::updateCoeffs() in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#7   at gaussLaplacianSchemes.C:0
#8  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#9  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#10  Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#11  Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/bin/chtMultiRegionFoam_TensorK"
#12
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14
Aborted
The message "Got here 00." was put in by me to diagnose where the problem occurs. It happens in "fluid/hEqn.h", when defining "fvScalarMatrix hEqn".
Best regards,
Bruno
Old   August 15, 2012, 06:11
niklas's Avatar
Niklas Nordin
Im guessing the boundary condition for T is using
K solidThermo;
and not
K directionalSolidThermo;
N
Old   August 15, 2012, 07:01
Bruno Santos
Hi Niklas,
Confirmed! It works!
Attached is the modified solver "chtMultiRegionFoamTensorK.tar.gz" and adapted tutorial "snappyMultiRegionHeaterDirectionalSolid.tar.g z".
To unpack and build the solver:
tar -xf chtMultiRegionFoamTensorK.tar.gz
cd chtMultiRegionFoamTensorK
wmake
To run the tutorial:
./Allrun
Modifications made:
  2. Modified the binary name in "Make/files" to chtMultiRegionFoamTensorK.
  3. As for the tutorial, did as Niklas indicated and modified the following files:
    system/heater/changeDictionaryDict
    system/leftSolid/changeDictionaryDict
    system/rightSolid/changeDictionaryDict
    You'll see the following modified lines:
    //K               basicThermo;
  4. In the tutorial, also modified "system/controlDict" to use chtMultiRegionFoamTensorK.
  5. Still in the tutorial, added in a piece of code for copying the STL files from the original tutorial, so that the attached file would be as small as possible...
Now to think of a way to make this more generic and post in the bug report
Best regards,
Bruno
File Type: gz snappyMultiRegionHeaterDirectionalSolid.tar.gz (10.1 KB, 45 views)
Old   August 16, 2012, 04:41
m_f
M
It works ! Thanks a lot.
Now, i would try to use the MultiRegionSimpleFoam, with KDirectionalSolid.
Do you think it's possible to modify this solver too ?
I'm not very adroit with the compilation of a new solver (your second step).
Best regards,
m_f
Old   August 16, 2012, 17:37
Bruno Santos
Hi m_f,
Attached are both modified solvers inside "chtMultiRegionFoamTensorK_v2.tar.gz" and the adapted tutorial "multiRegionHeaterDirectionalSolid.tar.gz" for chtMultiRegionSimpleFoamTensorK.
To unpack and build the two solvers:
tar -xf chtMultiRegionFoamTensorK_v2.tar.gz
./Allwmake
To run the attached tutorial:
./Allrun
The modification steps taken are pretty much identical.
Best regards,
Bruno
Old   August 17, 2012, 04:05
m_f
M
Hello wyldckat,
No words to describe my joy. Thank you very much for your investment - in terms of time - in this problem.
I saw that this solver use compressible proprieties for the fluid, is it possible to change a parameter (easily) to work with an incompressible flow ?
I have an other "easy" question but it isn't the same theme.
Thanks again.
Best regards,
m_f
Old   August 18, 2012, 04:07
Bruno Santos
Isn't chtMultiRegionSimpleFoam for incompressible fluids?
Old   August 18, 2012, 16:48
m_f
M
Hello and good Saturday,
I don't have my data on this computer but, I remember I had a text-file for rho parameter, and there is a variation in the fluid (between 1,25 and 0,98).
And I see on severals websites that it was a compressible solver (source : 1 & 2). Maybe a confirmation on Monday...You make me doubtful.
I don't know how to switch between compressible and incompressible or between perfect gaz and boussinesq approximation...
To conclude, I search a kind of solver which could solve all heat transfert (conduction/convection(natural or forced)/radiation) between solid and fluid regions, with incompressible flow. I thought that it could exist an incompressible fluids solver as chtMultiRegionSimpleFoam could be a kind of chtMultiRegionBoussinesqSimpleFoam (Combination of heatConductionFoam and buoyantBoussinesqSimpleFoam) including radiation.
Have a good week-end !
Best regards,
m_f
EDIT : Yes I've got a text-file for the density of the fluid.
Old   August 20, 2012, 06:44
Nikola
Hi to all of you,
Thank you very much for a great help you provided to me.
regards
Old   August 20, 2012, 08:38
Bruno Santos
OpenFOAM is open-source, which means you yourself can create "chtMultiRegionBoussinesqSimpleFoam"!
Having the file doesn't mean that file will be used by the solver.
Old   August 20, 2012, 10:42
m_f
M
Yes but this file is used during the resolution. It appears that solver write a new rho file at each iteration, and I can post process it.
:/ So I suppose..?
Extract of log.chtMultiRegionSimpleFoamTensorK :
Time = 10
Solving for fluid region fluid
DILUPBiCG:  Solving for Ux, Initial residual = 7.805865e-08, Final residual = 7.805865e-08, No Iterations 0
time step continuity errors : sum local = 7.809642e-07, global = -6.653458e-08, cumulative = -0.001835181
Min/max rho:0.997834 1.186319
You're totally right... I will begin to learn how create a solver.
Old   August 20, 2012, 16:24
Bruno Santos
:/ So I suppose..?
!! I've checked the original tutorial "heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeater" and it does create the rho field!
Mmm... well, it does make sense and SIMPLE itself doesn't imply incompressible flow. But since before I've only seen PIMPLE being used for compressible and SIMPLE for incompressible... I then wrongly assumed chtMultiRegionSimpleFoam was incompressible...
As for getting started with modifying solvers, check this tutorial: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Old   August 22, 2012, 07:34
m_f
M
Thanks ! I'm not crazy, What a relief ! x)
Let's have fun
Best regards,
m_f
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 15:42
syntax error on config.h ehooi Fluent UDF and Scheme Programming 3 November 9, 2011 10:05
[Other] Turbogrid power syntax la7low ANSYS Meshing & Geometry 0 January 15, 2011 22:20
Interpolation command '-interp-iv' in syntax file KM CFX 4 October 12, 2007 16:29
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
