Maximum Cells number of Engrid and Salome
Old   November 20, 2012, 02:54
Default Maximum Cells number of Engrid and Salome
edy
alsdia is on a distinguished road
Do you know what is the maximum numbers of elements that can handle Salome? 300millions elements is it possible?
And what about the maximum elements number of Engrid?
alsdia is offline   Reply With Quote
Old   November 20, 2012, 03:51
Sören Sander
Sören Sander is on a distinguished road
Hello alsdia,
As far as I experienced, in Salome the maximum number of elements is just limited by your hardware (Salome will crash, if you use too many cells). Thou I have to admit, I never simulated a case that was even close to 300M cells.
You could try to set up a easy case, e.g. a block. Then, use hexmesh and number of segment discretisation. Afterwards, you can refine your mesh step by step. Right now I have problems to create meshes with more then 3M cells, but this should be dependent on the hardware as mentioned above.
Sören Sander is offline   Reply With Quote
[Technical] Salome + Gmsh or enGrid for OpenFOAM? wwrfd OpenFOAM Meshing & Mesh Conversion 2 July 21, 2011 10:38
engrid: Internal volume mesh becoming coarser during boundayr layer addition Arnoldinho OpenFOAM 1 January 22, 2011 04:31
