dsmcFoam
hi
I try to run a problem with dsmc and mesh my geometry in gambit then convert to OF. I excute the checkMesh All of them its Ok but at the end line : Quote:
and I don't have the blockMesh. for example when run the cavity I type this order and now that I don't have the blockMesh what should I do? cd blockMesh icoFoam paraFoam is this correct: cd .....???? dsmcFoam paraFoam |
dear hadi
you mixedup several things 1- your import mesh has a skewness problem 2- dsmcSigmaTcRMax can not be find in your 0 folder 3-Allrun executes commands which are written in it successively, so i suggest to type command manually, or edit your Allrun file |
dear nimasam
I solved my problem mesh. I have a bit confused. now for run my problem I have one pc for run my problem then I don;t excute (./Allrun) in my terminal because this order run in parallel,is it correct? and after check mesh I type this in my terminal Quote:
in my 0 folder bounder T boundery U fD iDof q internal KE internalE mommentum RhoN RhoM dsmcRhoN |
Dear hadi
as you correctly point there is no dsmcSigmaTcRMax file in folder 0, so you can add it to folder 0 :) |
thanks
where can I give it? |
copy paste another file and rename it
"dsmcSigmaTcRMax" then you need to assign appropriate dimension to it ;) |
thanks nimasam
I have a problem for run my case.we run a code that create with fortran and we decide run my case together because we use one part of cpu for run fortran but this error can't let us: Quote:
may be you need to add this lib in your controldict to make it work,
but i suggest you to open new post and declare your problem there |
