-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   How to deal with a two-phase flow with a water-repellent boundary problem (http://www.cfd-online.com/Forums/openfoam-pre-processing/111092-how-deal-two-phase-flow-water-repellent-boundary-problem.html)
enoch December 27, 2012 03:03
3 Attachment(s)
Air passes through the blue-colored wall in the below channel, but not the water (attached). Could you give some tips on how to solve this problem using a two-phase solver or VOF available in OpenFOAM. Thanks in advance for your great help.
michielm January 11, 2013 12:11
This is a bit of a guess, but I think you should be able to set the velocity boundary condition as something like this:
v=alpha1*constant
which will make sure that you have a constant outflow for alpha1=1 and 0 outflow for alpha1=0
