Flat Plate analysis
Like Tree1Likes
  • 1 Post By wyldckat
Old   February 8, 2013, 19:29
Default Flat Plate analysis
Ben Graves
bgraves is on a distinguished road
Hi guys,
I am new to OpenFOAM and trying to do this same analysis for a class. I am having trouble with the grid from the plot3d format into OpenFoam.
I am using the grid found on the http://turbmodels.larc.nasa.gov/flatplate_grids.html website. I have successfully imported the grid using the plot3dToFoam command, followed by the autoPatch command. My main question is how to break up the bottom patch into the two "different" sections (ie the plate and the symmetry boundary condition).
Any input would be unbelievably helpful.
Thanks
bgraves is offline   Reply With Quote
Old   February 10, 2013, 06:54
Retired Super Moderator
Bruno Santos
Greetings Ben and welcome to the forum!
I think createPatch is what you should be looking for, for adding new patches in the exact place where you need them. I'll quote myself from an old thread:
Originally Posted by wyldckat View Post
@Elise: You can with createPatch. You can find several examples by running:
find $WM_PROJECT_DIR -name createPatchDict
If your geometry has good features (i.e., not trying to create a small patch in a flat surface), you can use autoPatch.
Best regards,
Bruno
Old   February 11, 2013, 11:51
Ben Graves
Thank you so much for your speedy reply!!! The model works perfectly now!
-Ben
Old   February 15, 2013, 19:02
Ben Graves
Sorry to ask again I am trying to do the same thing, only this time I am using the grids found on http://turbmodels.larc.nasa.gov/bump_grids.html. I used the same method that you helped me with prior. Except this time when I wrote the topoSetDict file for the right side of the bump, the faceSet that it makes looks like the following:
0
Below is the topoSetDict file:
actions
name f0;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (-25 0 0) (0 0 1);
name f1;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (-0 0 0) (1.5 0 1);
Any help would be greatly appreciated!
-Ben
Old   February 16, 2013, 04:04
Bruno Santos
Hi Ben,
You need to give it some thickness over the Y axis, something like:
actions
    name    f0;
    type    faceSet;
    action  new;
    source  boxToFace;
    sourceInfo
      box (-25 -0.01 0) (0 0.01 1);
    name    f1;
    type    faceSet;
    action  new;
    source  boxToFace;
    sourceInfo
      box (-0 -0.01 0) (1.5 0.01 1);
Best regards,
Bruno
laurentb likes this.
Old   February 18, 2013, 10:46
Ben Graves
Bruno,
I want to really thank you for saving my butt again
-Ben
Flow over a flat plate as an immersed solid hamed.majeed CFX 4 September 8, 2016 14:40
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 21:09
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 07:56
entrance of a flat plate mc Main CFD Forum 0 April 24, 2007 22:38
