topoSet simpleFoam parallelized run error
There is a parallel run issue in one of my cases in which I suspect that I have done something wrong with topoSetDict. === 1 === checkMesh.log fvSchemes fvSolution In my opinion, the setting is OK. === 2 === I execute the above commands respectively: Code:
blockMesh controlDict topoSetDict These are the system documents of the case. === 4 === I obtain the following error: Error_file In short: Code:
[0] --> FOAM FATAL ERROR: I have found some other forum pages which consider the same error message in a slightly different context. Therefore, I somehow couldn't adapt the given answers to my case. I appreciate any help. Many thanks in advance. |
Greetings HakikiCanakkaleli,
The problem is that the "sets" aren't decomposed as well. Try running topoSet in parallel: Code:
blockMesh Bruno |
Dear wyldckat,
Thanks a lot for taking your time and explain it to me. It perfectly works well now. Kind regards. |
What if I want to run snappyHexMesh in parallel (before topoSet and after decomposition, without creating new time directories) in your script? Thanks |
mpirun -np 2 snappyHexMesh -overwrite -parallel |
