Running starToFoam creates read vrt error in 0F 14
Old   July 10, 2007, 02:15
Default Hello. I was trying to run the
Shaun Darmody
shaun is on a distinguished road
Hello. I was trying to run the starToFoam mesh conversion utility for the sonicTurbFoam nacaAirfoil tute by issuing the following command.
lads@PhantomWorks:~/OpenFOAM/lads-1.4/run/tutorials/sonicTurbFoam/nacaAirfoil$ starToFoam .. nacaAirfoil nacaAirfoil
The following error was reported:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : starToFoam .. nacaAirfoil nacaAirfoil
Date : Jul 10 2007
Time : 15:42:37
Host : PhantomWorks
PID : 16387
Root : ..
Case : nacaAirfoil
Nprocs : 1
Create time
--> FOAM FATAL ERROR : Cannot read file "nacaAirfoil.vrt"#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 starMesh::readPoints(double)
#3 starMesh::starMesh(Foam::fileName const&, Foam::Time const&, double)
#4 main
#5 __libc_start_main
#6 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116
From function starMesh::readPoints()
in file readPoints.C at line 110.
FOAM aborting
Aborted
I did not have this error initially in reading the .vrt file last time I ran this utility in OF 1.3.
I went back to my OF 1.3 installation and tried again, but to no avail. It did not work either.
I currently use GRIDGEN as my grid generator and was planning to write out grids using the star-cd format.
What am I doing wrong? The OpenFoam case file structure is complete and the command has been issued correctly I believe. The foamCorrectVrt utility does not exist either.
I also tried outputting the grid in Star CCM+ format to take advantage of the ccm26ToFoam utility. GRIDGEN outputs the grid file with the extension '.inp'. This is not the '.ccm' extension I believe is expected by the ccm26ToFoam utility.
Can anyone help with this please?
Regards
Shaun.D
shaun is offline   Reply With Quote
Old   October 13, 2007, 00:27
Default Answering my own question from
Shaun Darmody
Answering my own question from some time ago, I managed to get this all to work this afternoon without any hassles. I simply ran the starToFoam command after placing the prostar files in the correct location. I.e the same path as the case directory.
My appologies for my ignorance and stupidity.
Thanks for the access to this software and its continued development.
Regards
Shaun.D
Old   March 13, 2013, 23:41
Default convert prostar mesh to openFoam mesh format
murali
murali is on a distinguished road
hello foamers
i have difficult to convert the prostar geometry files to openFoam mesh format in tutotrial of soniFoam,
can any one help me to convert the mesh file
murali is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
mpt read error 10054 zenith FLUENT 1 February 11, 2012 05:22
[Commercial meshers] StarToFoam checkMesh problems sylvain91 OpenFOAM Meshing & Mesh Conversion 1 June 15, 2006 04:36
Read error sampaio OpenFOAM Running, Solving & CFD 8 April 19, 2006 08:44
RE: Fluent Read Error Chris FLUENT 13 April 16, 2005 18:56
