Hi Isabel,
If you had provided images of what you're seeing, I would have been able to accurately diagnose the issue. ;) Since you didn't, I'll have to guess :rolleyes::
Bruno |
Excuse me I did not provide images.
This is the pressure field that I have in the original Fluent files: http://fotos.miarroba.es/lamasgaldo/...2755277B35.jpg http://fotos.miarroba.es/th/1a8c/305...2B55277B27.jpg And this is the pressure field that I read in OpenFOAM after fluentDataToFoam conversion: http://fotos.miarroba.es/th/da14/355...2755277B35.jpg The internal pressure is Ok, but the pressure at boundary conditions is not the same in OpenFOAM and Fluent This is my zoneToPatchName file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class wordList; location "constant/polyMesh"; object zoneToPatchName; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // /* (45 (2 fluid fluid)()) (45 (3 wall wall)()) (45 (4 wall symmetry)()) (45 (5 wall outlet)()) (45 (6 wall inlet)()) (45 (8 interior default-interior)()) */ 9 ( dummy //foam 0 - no fluent correspondence dummy //foam 1 - fluent 1 fluid //foam 2 - fluent 2 wall //foam 3 - fluent 3 symmetry //foam 4 - fluent 4 outlet //foam 5 - fluent 5 inlet //foam 6 - fluent 6 dummy //foam 7 - fluent 7 default-interior //foam 8 - fluent 8 ); After fluentDataToFoam conversion, the content of zoneToPatchName file changes to this: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class wordList; location "constant/polyMesh"; object zoneToPatchName; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 9 ( unknown unknown unknown wall symmetry outlet inlet unknown default-interior ) // ************************************************** *********************** // |
Hi Isabel,
I don't have much experience with converting Fluent data to OpenFOAM data, therefore I'm not familiar with any usual issues that can occur in these cases. Nonetheless, try using foamToVTK like this: Code:
foamToVTK -noPointValues Beyond that, I suggest you try a simpler test case. If the simpler test case has the same problems, please share the complete test case, so that I or anyone else can look into this. Best regards, Bruno |
Thank you very much. Now it works.
Problem with fluentDataToFoam (from OF 1.6 ex) in OF 2.3.1
Has anyone tried to compile and use fluentDataToFoam with openFoam 2.3.1?
I managed to compile fluentDataToFoam but no luck with any mapping yet. I have case and data files made with Fluent V17.2. I keep getting the long list of corrupted double-link list. Code:
*** glibc detected *** fluentDataToFoam: corrupted double-linked list: 0x00000000010f43a0 *** Any clues or suggestions? |
Caution for Fluent cases in which only the mesh was replaced
Great explanation Bruno.
However, note that this does not work if you load the .msh file into an existing Fluent .cas file. What happens is then that the Zone Section ID's in the .cas and .msh do not (have to) match. For the .dat file the ID's of the .cas are the important ID's for the zoneToPatchName file. |
Have you found a solution?
For me it works to create a .dat file with the averaged / mean fields using: Code:
UMeanx 402; The values of these scalars are correctly written to the .dat file but when I load the .dat file into fluent the values are wrong (the trend looks correct but the absolute values are way off). Any suggestions? Quote:
Here is a summary on how to use foamDataToFluent:
1. In more recent Ansys Fluent versions you need to change the data format from dat.h5 to .dat. Go to preferences/general and choose legacy as the Default Format for I/O. In the Console (Text user inferface) type: /file/binary-legacy-files? no Now you can export the .dat file by going to file/write/Data. 2. In your Fluent case go to boundary conditions: click onto each patch to see the ID numbers. Afterwards prepare a list for the file zoneToPatchName with the corresponding ID numbers and patchnames. Moreover, look at the cell zone conditions and also add the e.g. fluid id which is the "unknown" patchname in zoneToPatchName. constant/polymesh/zoneToPatchName: Code:
/*--------------------------------*- C++ -*----------------------------------*\ 4. Download the file (foamDataToFluent) and compile it. Copy zoneToPatchName to constant/polyMesh/. Set in the system/controlDict the startTime which equals the directory to which the data is converted to. Then run the command: foamDataToFluent YourFluentDataName.dat |
