March 13, 2013, 12:13 |
cyclic boundary condition
xxxxx
Hello everybody.
I'm trying to understand how cyclic BC works in OF211. I built a very simple mesh and imposed the cyclic BC on opposite faces. These faces are axis-symmetrical with respect to z-axis. When I solve the case i see that the cyclic BC doesn't work as i expect it to do. I post a snapshot of the cyclic faces. I would like faces A and C to be connected and B&D too, but what i get seems to be A connected to D and B connected to C. Can someone help me please? |
March 14, 2013, 16:41 |
Nickolas P
These two patches must be physically connected in some way. In blockmesh file you have to declare through the CYCLIC the projection of one patch to the other with some accuracy through the tolerance number. Be careful that the points on each patch the points should be exactly symmetrical otherwise you will problems with the blockmesh-ing. Then you simply set the BC's on 0 folder as CYCLIC on the variables you want to solve. Nickolas |
March 16, 2013, 02:25 |
xxxxx
Thank you for your answer.
Actually my mesh is made in open Salome and I import it via ideasUnvToFoam. The points on the two faces are symmetrical (the mesh is structured). Anyway I solved the problem by using createPatchDict. I convert the two patches in new patches connected each other and substitute them to the old polyMesh. It works but I would like to know if there is a better way to do this. |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 10:54 |
cyclic boundary condition | flotran | OpenFOAM | 3 | December 19, 2011 20:13 |
can I use cyclic boundary condition to modeling axisymmetric flow ? | mechy | OpenFOAM | 0 | July 8, 2011 14:16 |
cyclic boundary condition doesn't work in a tube ?? | Cyp | OpenFOAM | 6 | April 16, 2010 15:21 |
fan cyclic boundary condition | leejc | OpenFOAM | 0 | April 15, 2010 16:38 |
