Sutherland transport Coefficients
Does anyone know the sutherland transport coefficients (As and Ts) needed in thermophysicalProperties for O2 and H2? Thank you Stratos |
Hi Stratos,
I don't know if you solved your problem, but I use the coefficent, which I found in the combustion/firefoam/les/smallfire3D tutorial. They are in the file "thermo.compressibleGas" and they seem to be the same for all types of gas: transport { As 1.67212e-06; Ts 170.672; } Does anybody know, if they really are the same for all gases? |
Just an update on this. These coefficients are for nitrogen gas alone and in all of the tutorials are applied to all species (making viscosity and thermal conductivity independent of composition). This may or may not provide sensible enough results depending on the accuracy you are looking for.
Also a note on using multiple coefficients for different species. OpenFoam does some strange mixture rules (not mol or mass based). See more information in the thread here: https://www.cfd-online.com/Forums/op...strangely.html |
