buoyantSimpleFoam error
Old   March 26, 2013, 09:27
Default buoyantSimpleFoam error
Gabriel de PInho RImoli
Grimoli is on a distinguished road
Guys im doing a heat transfer case using buoyantsimplefoam Solver ,however when i type the command :buoyantSimpleFoam
Im getting the certain error :
--> FOAM FATAL ERROR:
Attempt to return primitive entry ITstream : /home/oem/OpenFOAM/gabriel-2.1.1/run/tutorials/pipe/constant/thermophysicalProperties::mixture, line 22, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'mixture' comprises
on line 22 the word 'air'
on line 22 the label 1
on line 22 the doubleScalar 28.96
on line 22 the doubleScalar 1004.4
on line 22 the label 0
on line 22 the doubleScalar 1.831e-05
on line 22 the doubleScalar 0.705
as a sub-dictionary
From function const dictionary& primitiveEntry::dict() const
in file db/dictionary/primitiveEntry/primitiveEntry.C at line 159.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:rimitiveEntry::dict() const at ??:?
#3 Foam::dictionary::subDict(Foam::word const&) const at ??:?
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::hPsiThermo(Foam::fvMesh const&) at ??:?
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) at ??:?
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) at ??:?
at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Aborted (core dumped)
What should I do about it??
Grimoli is offline   Reply With Quote
Old   March 26, 2013, 10:38
HECKMANN Frédéric
fredo490 is on a distinguished road
It looks like there is a problem with your declaration in the "thermophysicalProperties" which is in the Constant folder. Maybe the "thermoType" doesn't match your settings.
fredo490 is offline   Reply With Quote
Old   March 26, 2013, 10:50
HEy guys i found the error.It was because i was using old version of thermophysicalProperties.I copied the new version and it ran alright.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
user defined function cfduser CFX 0 April 29, 2006 10:58
