Home > Forums > OpenFOAM Pre-Processing
Need help Buoyant BoussinesqSimpleFoam and Pressure inlet/outlet boundary conditions
Like Tree1Likes
  • 1 Post By RynoLaub
Old   April 9, 2013, 06:00
Question Need help Buoyant BoussinesqSimpleFoam and Pressure inlet/outlet boundary conditions
Ryno Laubscher
RynoLaub is on a distinguished road
Hi Guys
I am relatively new to Openfoam and is busy learning the software I have already done a few of my own problems with success. Currently I trying to do the tuts I've done on Ansys during my studies at university. One tut is giving me a few problems, it will be much appreciated if someone could help me.
The problem I am trying to simulate is 2D laminar flow around a heated vertical plate in air. The solver I am using is buoyantboussinesqsimplefoam and the RAS properties is set to laminar. The problem has the following boundaries:
inflow, outflow, Symmetry, plate and front_back where the front_back is type empty and Symmetry is type symmetryPlane. The inflow should be a pressure inlet at ambient temperature T_amb and the outlet should be a pressure inlet outlet (to compensate for backward (reverse) flow) at T_amb. My question is could someone tell me how the 0/p and 0/U boundaries should be setup.
RynoLaub is offline   Reply With Quote
Old   April 10, 2013, 07:16
Ryno Laubscher
Okay I figured it out, for the inlet and outlet conditions in 0/U I used pressureInletVelocity and for the inlet/out in 0/p used totalPressure and the sim looks like it works. I will post the actual files and sim results later.
Mojtaba.a likes this.
Old   September 7, 2013, 15:42
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Yahoo to Mojtaba.a
Dear Ryno,
What values did you use for totalPressure boundary for p?
I am simulating natural convection in a pipe and I have some problems making the solution steady as it has to be.
I have set up U and p boundary conditions as you suggested, but I don't know about the values of totalPressure.
Do you have any suggestions?
Learn OpenFOAM in Persian for free, And ask your questions here.
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Thread Tools
Trackbacks are On
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 8 December 3, 2013 17:51
error message cuteapathy CFX 14 March 20, 2012 07:45
Problems with boundary conditions - velocity and pressure not zero M_Flodin FLUENT 0 April 1, 2011 09:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
