-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   boundary condition inside a cylinder (http://www.cfd-online.com/Forums/openfoam-pre-processing/115959-boundary-condition-inside-cylinder.html)
mohsen Khandan April 10, 2013 05:24
hi
I'm a new OF user.
I have a cylinder which has 10 holes on its side surface as inlets. there is a top outlet.
I try to model the flow inside the tube by icoFoam.
I know the inlet's surface area and also the volume flux(m3/h) and also inlets pressure so I can calculate the velocity inlet. I know the inlet temperature too.
I know the outlet pressure also,and its temperature.
but I don't know how to set my boundary condition and which kind of them should be chosen.:confused:
I look forward to see your helps.
thank you in advanced.
Mohsen Khandan
