immortality |
April 12, 2013 15:48 |
why "p0_3-.5*internalField(rho)*sqr(U)" gives error?
the BC is:
left
type groovyBC;
variables (
"p0_3=932190;"
fractionExpression "0<=pos().y&&pos().y<=.003?0:1";
valueExpression "p0_3-.5*internalField(rho)*sqr(U)";
value uniform 303975;//932190
gradientExpression "0";
and the error is:
[2] --> FOAM FATAL ERROR:
[2] [1]
[3]
[3]
Parser Error for driver PatchValueExpressionDriver at "1.34-33" :"syntax error, unexpected $end"
Context of the error:
- From dictionary: /home/ehsan/Desktop/shock_tube_constant_incomp/processor2/0/p.boundaryField.left
Evaluating expression "p0_3-.5*internalField(rho)*sqr(U)"
[2]
[2]
[2] From function parsingValue
[2] in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[2]
FOAM parallel run exiting
[2]
[3] --> FOAM FATAL ERROR:
[1]
[1] --> FOAM FATAL ERROR:
[1] Parser Error for driver PatchValueExpressionDriver at "1.34-33" :"syntax error, unexpected $end"
- From dictionary: /home/ehsan/Desktop/shock_tube_constant_incomp/processor1/0/p.boundaryField.left
[1]
[1]
[1] From function parsingValue
[1] in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[1]
[1]
[0] --------------------------------------------------------------------------
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0] --> FOAM FATAL ERROR:
[0] Parser Error for driver PatchValueExpressionDriver at "1.34-33" :"syntax error, unexpected $end"
- From dictionary: /home/ehsan/Desktop/shock_tube_constant_incomp/processor0/0/p.boundaryField.left
[0]
[0]
[0] From function parsingValue
[0] in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[0]
[0]
[3] Parser Error for driver PatchValueExpressionDriver at "1.34-33" :"syntax error, unexpected $end"
- From dictionary: /home/ehsan/Desktop/shock_tube_constant_incomp/processor3/0/p.boundaryField.left
[3]
[3]
[3] From function parsingValue
[3] in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[3]
[3]
mpirun has exited due to process rank 3 with PID 9936 on
node Ehsan-com exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[Ehsan-com:09929] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[Ehsan-com:09929] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Killing PID 9927
PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 9927 was already dead
Getting LinuxMem: [Errno 2] No such file or directory: '/proc/9927/status'
why?!;)
