[Sponsors] | |||||
Oli
Rep Power: 6 ![]() |
Hello Foamers,
i'm using a special commercial Foam Version for serveral years, especially simplePorousFoam and buoyantSimpleFoam. In the future we want to switch to the official openFoam. Is there meanwhile an application, that creates the Folder "0" with the necessary files "U" "T" "p" and so on, based on the boundaries in the polyMesh (for example every boundary is a wall). Or do you still have to create "U" "T" "P" by hand and then using changeDictionary? Best Regards and thanks! Oli |
Jose Rey
I ran into the same problem initially, and found out that you have to do a couple of things you have to do and watch out for. The transition will likely cause you grief:
Update: To create a Zero(0) folder, I have used an open source pre-processing tool called Helyx-OS. You might want to try it, it is available in SourceForge. Use the serial mode (as in single CPU) to get the zero directory at the case folder. Last edited by JR22; April 20, 2013 at 15:59. Reason: Added HelyxOS tool to create 0 folder |
Bruno Santos
Rep Power: 45 ![]() ![]() |
Greetings to all!
I haven't studied OpenFOAM 2.2 closely (yet), so I don't know if they've added anything new for setting up new cases. But I do remember reading something about PyFoam being able to do this... a quick search lead me to this presentation: http://www.tfd.chalmers.se/~hani/kur...011/pyFoam.pdf Best regards, Bruno
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| create a probe with fluent | Aenseeiht | FLUENT | 3 | April 29, 2010 03:27 |
| create own case for laplacianFoam | rahulrp | OpenFOAM Pre-Processing | 6 | April 8, 2010 00:03 |
| [ICEM] how can i create a consistent transitions between tet and hex? specifically my model? | snailstb | ANSYS Meshing & Geometry | 3 | March 15, 2010 21:26 |
| Folder structure from snappyHexMesh | elisenda | OpenFOAM Native Meshers: snappyHexMesh and Others | 3 | January 6, 2010 03:52 |
| Create new material: Natural gas | Van | FLUENT | 0 | August 18, 2005 04:55 |
