interCondensatingEvaporatingFoam
Like Tree6Likes
  • 4 Post By Lorenzo210
  • 1 Post By Lorenzo210
  • 1 Post By claudiocor
Old   November 18, 2020, 14:06
Default interCondensatingEvaporatingFoam
Cláudio Corrêa
claudiocor is on a distinguished road
Dears,
I need changing the value in constant/phaseChangingProperties but I don't know what the values mean in the tutorial. I need to simulate turbulent flow vapour-water in pipe.
Does anyone have any ideas of what these values are?
claudiocor is offline   Reply With Quote
Old   December 15, 2020, 11:59
Lorenzo
Lorenzo210 is on a distinguished road
Hi Claudio,
The Lee's phase change model is used in the tutorial condensatingVessel. The evaporative mass source is calculated as:
m_evap = coeffE * rho_liquid * alpha_liquid * (T - T_sat) when T>T_sat.
Here there is the model's source documentation:
https://www.openfoam.com/documentati...87_source.html
In literature you can find many info about the Lee's model, and what the constant coeffE means.
In this link, for instance, you will find a desciption of the phase change model used in a different solver, icoReactingMultiPhaseInterFoam: https://www.openfoam.com/documentati...ls_1_1Lee.html
BE CAREFUL: in this link there is the equation you can find in literature too; you'll see that the equation used in interCondensantingEvaporatingFoam lacks of a term (1 / T_sat), so the coefficients are defined differently.
Finally, the evaluation of the coefficient:
many numerical simulations use a different coefficient, which is not predictable. I'll try to make that simple: if you use a low value, your calculation will probably find convergence, but the accuracy won't be so good..This will make
the interface temperature be higher than T_sat (ideally you should find T_int=T_sat). On the other hand, if you use a very high value of the Lee's coefficient, you will have accurate results, but the calculation may fail. Usually, you should start with a coefficient equal to 0.1 and then see what happens in your simulation (I found even values in the orders of 10^7 ). Sometimes (T_interface - T_sat)= 1 K is a good result, but depends on the particular situation.
The coefficient that you have to put in phaseChangeProperties should be equal to the Lee's coefficient divided to T_sat.
Hope this is helpful.
Lorenzo
PS: which version of OpenFOAM are you using? I'm currently working on openFoam-v2006, and I'm interested in two-phase flow boiling inside a channel (I'm trying to use both interCondensatingEvaporatingFoam and icoReactingMultiPhaseInterFoam), so maybe we can discuss about that.
silviliril, Pavithra, ZZW and 1 others like this.
Lorenzo210 is offline   Reply With Quote
Old   December 15, 2020, 18:44
Cláudio Corrêa
Hi Lorenzo. Thanks for your reply.
Your information will help me a lot.
My OpenFoam version´s v2006. My interest is in a two-phase flow cooling inside pipe.
Yes, we can discuss how to simulate our cases in interCondensatingEvaporatingFoam.
Regards.
Old   December 16, 2020, 05:11
Lorenzo
All right, I made the example taking into account the evaporation rate, but for the condensation process it is the same thing except for the gradient of temperature, which is (T_sat -T) instead of (T - T_sat).
I tried using the "constant" phase change model in OpenFoam v1812 for annular flow boiling. The evaporation rate is distributed uniformly on the liquid zone, but I want the evaporation process to be located along the interface liquid-vapor.
For that reason, I'm studying the "interfaceHeatResistance" model, which is available only for OpenFoam v2006.
It is a little challenging because I'm not so expert on OpenFOAM and C++, and there are few documentations, tutorials and forum discussions about interCondensatingEvaporatingFoam.
Let me know if you can achieve some good results and if you have any problem.
Regards.
Pavithra likes this.
Old   December 16, 2020, 11:55
Cláudio Corrêa
Regards.
Yes, I agree.
This model I do not know. I'm trying to simulate water-steam two-phase flow whith k-epsilon model but my simulation is blowing up. I started with first order solvers and after a while I switched to second order solvers. But the k equation is unbounding and the message in terminal is "bounding k ...." .
Exactly, there is a little documentation and tutorials for the validation of these cases. My experience with OpenFOAM and C++ started in 2018 so I'm still learning about that.
I haven't yet good results and I have many problems
Regards
