SimpleFoam / Laminar flow / Why k & w are still required?
Old   May 8, 2013, 07:27
Default SimpleFoam / Laminar flow / Why k & w are still required?
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
== 1 ==
A steady-state & laminar (Re << 100) flow case is run with simpleFoam. (Considering icoFoam is suggested to be used for only transient laminar flows in the User Guide). The turbulence modelling is kOmegaSST.
== 2 ==
I wonder why I need to set up k and w parameters in the numerical setting even though the flow is laminar?
== 3 ==
RASProperties/transportProperties/turbulenceProperties
k&Omega Settings
Many thanks in advance for any help.
HakikiCanakkaleli is offline   Reply With Quote
Old   May 8, 2013, 10:50
Matze7 is on a distinguished road
why do you want to use the kOmegaSST RASmodel for your case?
just replace
"RASModel kOmegaSST;"
with
"RASModel laminar;"
then it should work.
regards
Matze7 is offline   Reply With Quote
Old   May 8, 2013, 11:19
== 1 ==
Thank you very much for your answer. Simply I am confused how to properly set the laminar case. This case, however, has been computed without any error. Nevertheless, the numerical setting was not the right one to model a laminar flow as far as "k" and "omega" were input.
For a future reference for the novices like me, the right setting is -the remaining above is identical-:
RASProperties/transportProperties under "constant" directory.
In addition, "turbulenceProperties" under "constant" directory and "k" & "omega" under "0" directory are omitted.
== 2 ==
This arised another question, though. Why do I need to input "turbulence" keyword in the "RASProperties" file although I input "RASModel laminar;" ?
When I do not input this keyword, the terminal gives me an error message:
--> FOAM FATAL IO ERROR:
keyword turbulence is undefined in dictionary
If I need to input the keyword just for completeness; why "turbulence on;" could also work well (at least in terms of numericals - the simulation can be run) ? Could anyone tell me what this means?
Many thanks in advance for any reply.
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 18:35
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 11:35
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 03:20
Divergence of Laminar Flow With Eddy ??? Peter Kostka Main CFD Forum 3 May 9, 2002 18:02
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
