-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Meshing with Salome (http://www.cfd-online.com/Forums/openfoam-pre-processing/117847-meshing-salome.html)
samiam1000 May 16, 2013 04:29
Meshing with Salome
Dear All,
I am trying to set a chtMultiRegionFoam case. I started from a Salome mesh that seems to be ok.
Later, I have exported 5 different .unv file (air, solid_i, i = 1:4).
What sould I do, now? How can I get a single mesh, starting from 5 different files?
Can anyone provide an idea?
Thanks a lot,
Sam
cutter June 5, 2013 04:57
Have a look at mergeMeshes and stitchMesh. Good luck!
cutter
zhengzh5 October 4, 2013 13:22
Originally Posted by samiam1000 (Post 427933)
Dear All,
Thanks a lot,
Sam
the other way around is to mesh the entire domain in salome and subdivide them into regions inside salome by creating volumes/groups. that way when you import the mesh into OpenFOAM, it will recognize the regions after you apply splitMeshRegion -cellZones.
